No UI shows after enable Editable Node Tools
   3342   3   1
Unity version 2019.4.18f1
Houdini Engine 18.5
Hi guys,
I updated Unity and Houdini Version recently, and found that the UI of edit nodes tools in houdini engine was gone. Does anyone have the same problem? I tried both of the paint node and the attribpaint node, and keep the node unlocked. I also set the type properties
Hi, the pictures on your post are broken, but in order to enable the editable nodes UI, you have to check the option in Asset Options > Enable Editable Node Tools.
Here is an example of an HDA using the attribute paint node.
AttribPaint.hda (57.2 KB)
Hi,josyzhaocn,
have you fixed it?
I am working on unity 2020.3.33f1 houdini 19,and I have the same problem,
for this version,there is no "enable editable node tools" on the hda node,but there is a "editable nodes tolls enabled" on "HDA_Data" node.I tried to enable it ,but still no UI showed out.
In my hda,there're "attribPaint" and "curve1" nodes which could be edited.
just read the document again,
turn on "editable nodes tolls enabled" on "HDA_Data" node is the right way,but what i did it wrongly is that I set the paint node to be the editable node,it should be the "output0" node inside paint node,and the paint node should be unlocked.
