no environment mapped paths found! macOS
   Views 3222   Replies 1   Subscribers 0
just started houdini and unity engine and couldent installed properlly
, i guss because of thse some hda are not working
Screenshot 2021-03-12 at 11.15.49 PM.png (93.1 KB)
Hi! A few things:
- Unless your HDA explicitly uses a custom environment path, no additional mapped environment paths should be necessary for loading a basic HDA. You can send the HDA if you want me to check if this is the case. Also, sending the error log would be nice as well.
- Make sure that Assets/plugin/unity_houdini.env file exists. It is relative to your project folder.
- All environment paths must be prefixed by "HEU_ENVPATH_", e.g. HEU_ENVPATH_COMMON_HDAS=C:\Dev\Houdini\CommonAssets . See: https://www.sidefx.com/docs/unity/_environment.html [www.sidefx.com]
Edited by anthonyt2 - March 23, 2021 11:24:06
