Change parameter on multiple nodes in pinned Parameters pane
1383 0 1- Michael Battcock
- 30 posts
I usually work with a parameters pane linked to a network view, however the pane is then considered "pinned". This means I can't select multiple nodes in order to change their parameters at once (it only shows the parameters for the last selected node). Is there a way to change this? Preferences for example? I was sure this used to work as I expect..
