Losing opacity after using instancer
   1617   2   1
I'm running into an issue when rendering with arnold some instances I've created with the insntancer node in solaris, for some reason the prototypes (USDs I've previously created with its material assigned) before being used on the instancer have the material fine, with its transparency correctly settle (checked with a render), but after I do the scattering I want in the instancer for some reason the prototype lose the opacity channel or it just doesnt show up in the final render.
Is there anything that I should do or touch that may not be obvious to fix it? any configoration that I should twek so the opacity channel works just fine?
I would really appreciate any help. Thanks in advance!
I have exactly same issue.
Is this Arnold thing?
Found it...
try tag off "Only Copy Specified Prototype Primitives" under options in instancer node.
