Regarding the gradient material
   2298   2   0
I am trying a material color, bottle mouth is light, the middle is dark, the bottle bottom is light;
I tried synthetic materials and direct gradient colors; but the rame node can only control the left and right gradients, and cannot be changed to vertical Gradient or other angles,
is rame node inappropriate for this situation? I am still confused that the ratio controlled by rame default is completely inconsistent with the color ratio after application. Why is this? I checked the help document, but did not find the answer. I hope someone can help me. thanks!
Edited by geodhk - July 31, 2021 08:00:05
test.hiplc (1.1 MB)
like this
The ramp is expecting a float value but you are plugging in a vector, position, so it is just using the first value, x, for the gradient. To get what I think you want simply add a "vector to float" node between the position and ramp nodes, then you can plug in the y value to the ramp to get a vertical gradient.
