gradually melting animated object
   2224   3   0
I d like to gradually melt(deform) an animated object over time. Could someone please check the scene attached...
Many thx!
Lucas
EDIT: just realized i forgot to update the "melt" attribute inside a SOP solver DOP. unfortunately this does not work slong with a copied Particle Position attribute.
Help would be very much apprechiated.
Edited by Fest - Aug. 6, 2021 12:13:31
anim_melt_01.hip (797.2 KB)
using match P along with the attribute transfer did the job. higher substeps were needed to solve the sim....
anim_melt_01.hip (870.3 KB)
another question about that topic
why i have to cranc up substeps to make this work ? i have anoher scene with the exact same setup but a different scene scale. the solve does not work and simed particles dissapear.
is there another, more efficient way to set this up ?
Did you ever solve the particles disappearing?
Fest
