Extracting cutters from RBD MaterialFracture
2673 3 1- kahuna031
- 897 posts
- npetit
- 407 posts
Unfortunately the cutting planes get generated recursively from the previously cut pieces, as such, in order to extract them you'd still need to perform the cuts and store the cutting planes at each step, making sure to separate them out before processing each piece again.
Since they encompass each piece with some extra padding to ensure the cuts go through the whole way, you'd then need to cut your Mesh B recursively by each generated cutting plane in the same order they were generated in the first place - you wouldn't be able to simply gather all cutting planes and cut in one go unless you boolean union the lot and go through and painstakingly cleanup all the protruding faces to ensure no partial cuts.
If your Mesh B bounds differ from the bounds of Mesh A, the cutting planes might not extend far enough to generate clean complete cuts in the first place.
- tamte
- 8780 posts
maybe you can fracture a box big enough to contain either of the meshes
and then for each of the fractured box pieces intersect with MeshA, MeshB, MeshC, ... to get similar piece cut out of any of those
so in theory you will get them cut the same way
havent tried, just an idea
Edited by tamte - Sept. 1, 2021 18:24:44
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- Jikian
- 144 posts
