In the Compile End Block you can disable 'Enable Compiling'. In this way you can run (the nodes in) the Block even with unsupported nodes.
Now suppose I would like to 'invoke' a Block of nodes (with unsupported nodes) purely for this feature that is mentioned in the docs:
"You can create a digital asset with a parameter that accepts a reference to a compiled block, and then use that block as part of the asset’s operation."
How can we do it? The 'Enable Compiling' parameter doesn't translate into the 'Invoke Compile Block'. You still get the error of unsupported nodes.
Is there some kind of other way?, ... An alternative for the hypothetical 'Invoke HDA SOP' or the 'Invoke Subnet SOP'? I think you know what I mean.
Hope there is a way, or else that we can get the 'Enable Compiling' parm also on the Invoke Compile Block SOP.
Thanks,
