I'm trying to create a screenshot of my model library which I'll pipe into ImageMagick to create a montage. Rather than rendering each model, I'd just like to take a viewport screenshot.
My setup is pretty simple.
* A filepattern node which scans for all .fbx's in a folder.
* A geometryimport node to pull in the geo.
* attribcreate to create a string with the key "image_path" and the value pointing to where I want to save the flipbook image
* lastly a pythonscript node to create the viewport (flipbook) snapshot
When I run it, I get correctly named images saved to the /flip directory, but they're all the same content.
I've tried calling .draw() on the GeometryViewport and a few other things.
Any advice?
Screenshot model library in TOPs
2805 3 3- colinsenner
- 9 posts
- benC
- 49 posts
I don't know how's the sop part of the file looks like so I could be wrong, but I could think of two things that could be causing problems:
- The geometry file name attribute didn't pass it to the file node in sop correctly
- Flipbook could have problems working with pdg since it's integrated with the viewport, use Opengl or mantra instead
- colinsenner
- 9 posts
benC
Can I use OpenGL or Mantra do just do a viewport screenshot? Is there any documentation for it in the python docs do you think?
- benC
- 49 posts
