WIP - Unity Procedural Animated Seaweed [GameArt]
   4170   1   1
Hello, this is my first project in Houdini. I am more on shaders and i wanted to see what i can do with Houdini. As first project I decided to make seaweed generator with animation and geometry calculation on the run with compute shader. In the end works quite well.
Features:
- LOD support
- image processor removing any unnecessary triangles
- procedural Texture Generator with Substance Designer
- player collision and damping to water level
Parameters:
- number of Leaves and stalks
- min, max size for leaves
- number of leaves on texture atlas
- random direction and scatter
- curves for wind, bending
- bending and twisting the stalks
To do:
- Setting up wedges and removing unnecessary parameters
Screenshot of the network
Calculated vectors that will be coded in mesh.
Tool in Unity
Test in simple enviro
Edited by Gand - Sept. 30, 2021 17:10:56
