Creating masks in Volume Vops
   Views 3197   Replies 4   Subscribers 0
Hello, please what is the best way to create masks in the volume vop so i can control the areas the noise affects.
Thank you!
I would like to know this as well
thanks
konxompax
thanks
What are you trying to do? I'm not sure what to recommend, as 'use nodes' isn't that helpful I assume.
I assume you want to add some noise to a mask area
ImaobongKennedy
Thank you!
konxompax
thanks
noise_mask_volume.hip (157.9 KB)
Benyee
ImaobongKennedy
Thank you!
konxompax
thanks
yes! this is it. thank you so much
