Vat Normals not updating with particle rotations
   Views 1660   Replies 1   Subscribers 0
I have a fluid vat with unpacked normals (separate normal map) emitting from a Niagara particle system. It all works fine, but once the particle rotates, the normals on the vat do not update. Any ideas on how to fix this? I tried transforming the normal from particle mesh space to world space, but that didn't help either.
thanks
JasonJ3d
thanks
Can you try a quick fix of transforming it from world to mesh particle space? I will probably need to look into a more permanent solution. Thanks for catching this issue.
Mai Ao
Senior Technical Lead of SideFX Labs
youtube.com/@notverydarkmagic
