Debian 10 vs Windows 11 (huge performance difference)
   9584   10   1
well i have 3900X ryzen and yesterday i want to install new OS and i decided to check the performance between debian 10 and windows 11 to know which OS to install and when i see the result my eyes comes out from their place when i compare karma in solaris with the demo files from sidefx in houdini 19.
in debian 10 (1:47 min) :
in windows 11 pro (3:31 min):
and i never touch the scene configuration i just open it and render it in karma solaris
i know their is a 15%-20% difference between linux and windows but not almost 50% .
and i test it 4 times just to be sure in different scenes and in karma CPU its always the same performance differences
anyone have that issue also?
Edited by habernir - Nov. 2, 2021 03:18:10
60f191a4-cb7d-4ffa-96ff-c1e34ad63128.jfif (56.2 KB)
754f55c0-d5e0-4327-b7b4-317693fd0d06.jfif (52.3 KB)
Unfortunately, I can't switch to Linux because of Zbrush and Adobe ecosystem. But recently I had a weird thought, what if to get threadripper 32-64 cpu, install Debian with HQueue server for simulations and rendering, and run virtual guest machine over it with Windows and Houdini for working.
Edited by FaitelTech - Nov. 2, 2021 06:29:03
habernir
There's currently a massive problem with AMD Ryzen CPUs on Windows11 (it's a bit like back when the threadrippers 2990wx and Windows10 didn't like each other).
It's a combination of a Windows 11 scheduler bug and also L3 cache issue. This is also nothing that SideFX can do anything about, you will have to wait until Microsoft fixes its system.
If you're still in the setup phase, you might try if Windows10 works better for you (it should).
Martin Winkler
protozoan
habernir
its happen even after i updated windows 11 and install the latest chipset drivers from AMD (and they write that it sould fixed it by update windows 11 and install the latest drivers)
soo may be they still doesn't fix it or its a bug in houdini 19
Edited by habernir - Nov. 2, 2021 11:17:06
Just to add - Windows 11 isn't yet supported: https://www.sidefx.com/Support/system-requirements [www.sidefx.com]
Adding to this…
I'm seeing around 100% performance gains on Mint Linux 19 vs. Win10 for Threadripper 1920X machines. Both on the network rendering the ALab. Linux 20mins, Windows 40mins.
Andy_23
Adding to this…
Is this related to the texture file handle bug that was supposed to be fixed? Have you tried with a scene that uses RAT textures? What version of Houdini are you testing? I remember there was an issue reported a little while back that showed massive performance differences between windows and linux when textures were involved, but I believe it was fixed.
Hey jsmack, the tests I ran was with the ALab scene. I have yet to have luck with the modify path LOP to have it load the .rats instead of the .jpgs and .pngs It's the 19.0.383 build.
Do you have a tip?
Edited by Andy_23 - Nov. 4, 2021 17:57:46
So I've searched and replaced the USD files on disk and the JPGs are now loaded as RATs. This didn't have an effect on the render time.
How about XPU on Linux Mint, I love Linux Mint, but I always had trouble with graphics cards drivers!
Windows is a user friendly platform. However, at work we can run minimal Debian (or other small footprint distributions of Linux+GNU software) machines as VM:s quite easily without almost any resources. As soon as we want to run anything Windows we will need to double up hardware or more. This is because Windows has a lot of things going on simply to be more user friendly.
If you are using Windows maybe take a look at tools that will remove or disable processes that you do not need. For example, if your system run many threads simultaneously it will also disturb the CPU:s caching feature (IRQ:s and threading). Long ago, when Windows was my only OS for a while there existed various "hackish" tools that would disable unwanted processes. Today, I have no idea what they are called.
For rendering, in an ideal system, the CPU:s and GPU:s are only bothered with rendering and can fully utilize optimization features. With Linux/GNU versions usually you have the option to only install as few background processes as you desire. However, I've also seen some variants that are a bit "data" heavy by default.
Although I'm quite biased towards Linux+GNU probably for a larger VFX house I think having Windows workstations plus Linux+GNU renderfarms is probably what will work for artists. As for me I do not believe in running a VM for a workstation, because you loose some valuable performance and might get some issues with GPU passthrough. (maybe multiple GPU:s could solve that)
There are those who use Win+Linux on two separate machines as a standard approach. It is possible to VNC between them also, for example TurboVNC+VirtualGL will work with Houdini for free (and it is very good, however the server is only supported on Linux and OSX, but the client exist for WIN/OSX/Linux).
Edited by SWest - Jan. 11, 2023 16:59:47
