How to use new hou.logging from 19.0?
   3548   6   0
Just couldn't figure it out from the documentation how to use it in hom.
It looks great actually, but:
- How to fire my own LogEntry?
- Is there a way to register a custom source (for example my viewer state)
Also is there a way to pipe stdout to the new logging?
You should be able to add your own sorce using HDK:
https://www.sidefx.com/docs/hdk/class_u_t___universal_log_source_registration.html [www.sidefx.com]
I don't think this is exposed thru HOM yet.
(There is also HOUDINI_DEFAULT_LOG_SOURCES env var you may need to set).
Creating new sources and sending logs to these sources has been added to HOM in 19.0.436.
Your last question makes me think you haven't created a new Log Viewer pane yet? Once you enable logging with the far left icon menu, that same icon presents a list of all avaialble log sources (including stdout).
That's great! Thanks!
I actually did just enabled all and completely missed that stdout was there.
Also I tested it with vex assuming that it catch it but it doesn't right now. Which probably could be a good source option as well.
Like in general I was thinking this is the finally replacement for houdini console window (I'd also prefer that it won't popping up if LogViewer is enabled)
I was also pretty keen to checkout/use hou.logging in some of my hda PythonModules.
A couple of simple examples in the docs/docstrings would go a long way to help get up and running quickly.
This seems to be the only post that comes up on the topic.
Logging provides a standard api that compatible with builtin python logging.
I think the easiest way is to create a custom handler for the viewer. Consider this simple example
import hou
import logging
HOU_SEVERITY_MAP = {
    logging.DEBUG: hou.severityType.Message,
    logging.INFO: hou.severityType.ImportantMessage,
    logging.WARNING: hou.severityType.Warning,
    logging.ERROR: hou.severityType.Error,
    logging.CRITICAL: hou.severityType.Fatal
class HouLogHandler(logging.StreamHandler):
    def __init__(self):
        super().__init__(self)
    def emit(self, record: logging.LogRecord):
        hlog_entry = hou.logging.LogEntry(record.msg,
            source_context=record.name,
            severity=HOU_SEVERITY_MAP[record.levelno],
            thread_id=record.thread)
        hou.logging.log(hlog_entry)
logger = logging.getLogger("Tool")
logger.handlers =[HouLogHandler()] # addHandler in actual code
logger.setLevel(logging.DEBUG)
logger.info("Info message")
logger.warning("Warning")
logger.error("Error")
That way you'll see something like this:
With custom handler it's easier to control it and also you can use familiar python logging.
Unfortunately there are couple of issues.
  • While custom sources can be created they are not recognized by LogEntry. It always goes to the Python Logging (that's why I used context for logger name)
  • There is no filter in the viewer by level. I'm just used to this behavior, it's not always convenient to set levels on particular loggers.
For anyone else ending up in this topic the logging doesn't have to be as fancy as above.
A minimal example would be:
entry = hou.logging.LogEntry(message = "alive!")
hou.logging.log(entry)
If you want to log onto disk, you could add in the beginning
sink = hou.logging.FileSink(filepath)
sink.connect("Python Logging")
