Hey guys,
I have a scene, I have camera, the viewport render is done using the camera. However, when I try to render to Disk or to MPlay, I always get the error:
No cameras found in the USD file
I tried everything...I cannot submit the hiplc file, it's a huge simulation data, etc.
No cameras found in the USD file - Karma rendering
10428 23 4- szmatefy
- 141 posts
- mtucker
- 4525 posts
I'm sure the amount of data isn't relevant, so maybe you could trim out the large data and submit a smaller file that demonstrates the problem? One way to remove data from a USD file is to use a Configure Stage LOP after your Sublayer LOP to isolate the parts of the scene you want to keep, then save it out with a USD ROP set to "flatten stage". It should be easy to validate that you've kept the parts you want using the scene graph tree. Then feed this new smaller USD file into your hip file and if it still demonstrates the same behavior submit it to support.
- Hamilton Meathouse
- 200 posts
- szmatefy
- 141 posts
mtucker
Thanks! I'm super rookie with Solaris, I just assemble scene for rendering, but I figured out what you said, and exported an USD ascii file. I checked it, and found the camera definition, so I really don't get, what's going on...Fun fact, it works in the viewport (renders using the camera) but if I want to Render to Disk or MPlay or Background, it fails...
I do appreciate all help guys, I need to finish this image in the weekend for my client.
- jason_iversen
- 12672 posts
I think some interactive workflows will just use the first camera found if there is no good camera specified, but offline tenders are more careful (strict).
Edited by jason_iversen - Nov. 15, 2021 12:52:24
- szmatefy
- 141 posts
- Mark Wallman
- 700 posts
- jason_iversen
- 12672 posts
szmatefyPerhaps in this scene the camera is deactivated or something?
But what qualifies as a good camera? I've set it up properly, in my other scenes it works, only this scene screws it up...
> usdtree /usr/tmp/bar.usd --flatten --mask /cameras/camera1 / `--cameras [def Xform] `--camera1 [def Camera] (active = false)
- mtucker
- 4525 posts
Attached is a hip file that loads your usda file, adds a cube (because the usda has co geometry so there's nothing to see), and lets you either output the combined usda file or render an image directly. Both approaches work fine without any complaints about the camera for me. Can you post a hip file to go along with your USD file to demonstrate the issue?
- szmatefy
- 141 posts
jason_iversenszmatefyPerhaps in this scene the camera is deactivated or something?
But what qualifies as a good camera? I've set it up properly, in my other scenes it works, only this scene screws it up...> usdtree /usr/tmp/bar.usd --flatten --mask /cameras/camera1 / `--cameras [def Xform] `--camera1 [def Camera] (active = false)
Camera is active in the Scene graph...
- jason_iversen
- 12672 posts
szmatefyOk that was just a guess in absence of any real information... just follow what Mark suggest then
- szmatefy
- 141 posts
- 5D
- 42 posts
- jason_iversen
- 12672 posts
I very quickly tried this with the Beach Tank shelf tool and also got the same behaviour. It appears that the Karma ROP's LOP subnet is importing cameras to
I didn't get to the bottom of why playing with the toggling the
Anyhow, an easy repro for SideFX, at least.
/camera
but the Karma LOP is trying to render with (pluralized) /cameras/*
, which looks like a bug in the Karma ROP setup. I think the "fallback to the first camera in the file" is always kicking in. That's A problem, but not THE problem, though...I didn't get to the bottom of why playing with the toggling the
whitewater_import
causes husk to complain suddenly about the missing camera. When looking at the USD if I set the USD Output Directory and then usdview/usdtree -f the RENDER.usd, I see that it just doesn't contain all the prims it should. Perhaps the USD generation is silently failing on outputting the whitewater VDBs? This results in the camera just not being in there, so there is no camera for husk to fall back on. As well as the issue itself, it points maybe to a lack of catching an error during USD output?Anyhow, an easy repro for SideFX, at least.
Edited by jason_iversen - Nov. 18, 2021 01:52:45
- robp_sidefx
- 504 posts
jason_iversen
Interesting. It looks like there's a conflict for the name "render". The whitewater_import node ends with a "render" SOP and ends up generating render.usd ... then the "main" USD ends up as "render2.usd". If you rename the SOP in the whitewater_import to "render_null" (or anything different) then "render.usd" will be used for the "main" USD again (with the camera).
I'll look into a better fix, but hopefully this keeps your project moving forward for the time being!
- Rob
- jsmack
- 8046 posts
robp_sidefxjason_iversen
- Rob
why do the layers from the usdrender node endup in a flattened folder structure instead of in node paths, i.e. {usdroot}/obj/geo1/sopname.usd
this is how they write out of the usd rop.
- robp_sidefx
- 504 posts
jsmack
The USD Render ROP LOP internally uses the "savetodirectory" output processor so that all the files are self-contained within a given directory for rendering. You can reproduce the same behaviour in the USD ROP LOP by enabling the output processor there too.
Perhaps this processor shouldn't strip directory structure and instead be a "reparenting" operation (i.e., a file that would have been /path/to/asset.usd would go to /render/path/to/asset.usd instead of /render/asset.usd). I'll need to dig into the history and motivation for its current design a bit more.
- szmatefy
- 141 posts
- jason_iversen
- 12672 posts
szmatefyToo late! robp_sidefx (above) is SideFX Staff
Thanks you guys, I'll then report it to SideFX, maybe they can help!
- szmatefy
- 141 posts
