I'm trying to open the file provided by the RETARGET THE CMU MOTION CAPTURE DATABASE tutorial on the sidefx site.
I get an error from the mocap import node saying failed to open. I understand those files are supposed be downloaded and unzipped by the node but it looks like it's not working for me. I tried Houdini 18.5 and 19. I must be doing something wrong.
Thanks for your help!
Retarget CMU mocap tutorial by Luca Pataracchia question
4337 6 1-
- DGinz001
- 18 posts
- lucap1
- 31 posts
so it looks like the looks like the construction of the file archive in http://mocap.cs.cmu.edu/allasfamc.zip [mocap.cs.cmu.edu] has changed since I wrote this tutorial. Which is why this node can't find the files. If you did around the expanded archives directory structure you should be able to fine the files. As for running this in h19 it looks like there an issue in the TOP network. workitem expand is not creating work items properly. It might be a bug. I'll check into it and let you know.
- lucap1
- 31 posts
- DGinz001
- 18 posts
- lucap1
- 31 posts
My sincere apologies for the delay. Attached you'll find a copy of the file that works in h19. There's a bug in workitem expand that requires us to set "generate when" to "each upstream item is cooked" in order for it to generate work items. This bug should be corrected shortly. Also it looks like h19 didn't like the values in /obj/manual_retarget/rigmatchpose2, so I created a new node rigmatchpose3. Seems to be working now. Let me know if you run into any issues.
Regards
Luca
Regards
Luca
- DGinz001
- 18 posts
Hello Luca,
Thanks so much for taking the time and transferring your project to Houdini 19! I really appreciate it. But for some reason I can't get this to work on my end. I get some errors opening the file which I attached here. I couldn't find the asf and amc files so I downloaded them directly from the CMU Graphics Lab site and relinked all the skeleton and mocap files but then I get a distorted mesh . I might not have the correct asf and amc files, I just looked for the same numbers in the file names. You think that might be the problem?
Thanks again!
Daniel
Thanks again!
Daniel
- NicTanghe
- 219 posts
