How to output RBD to be in my Sop Level
   4591   3   1
Hi again
I am trying to find out How to output RBD to be in my Sop Level so not only being able to see in DOP but also in SOP level?
I believe you can use Object Merge SOP and write for object:
/obj/dopnet1:rbdobject1/Geometry or for all rbd objects :
/obj/dopnet1:*/Geometry
bern
groups seem to work to for isolating specific peices of the simulation .. on this topic,
I ran into a problem a few weeks back where I wanted to have the invididual RBD objects' transform effect objects which would go inside of them (to be the parent pretty much) … after .. they were simulated.
So, I came up with this hack-job that used 3 points to calculate the up vector and then applied the transform / relative rotation etc. But is there a simpler way? Just to somehow access the individual transform of an RBD?
Thanks it worked!
Appriciate.
