Hello.
I'm getting an error when I press any help icon of any node.
The console opens and gives the same message over and over "Network service crashed".
The help window opens aswell but with nothing on it.
When this happens I have to restar houdini as the system turns very slow maybe due to the looping error.
I'm on Houdini Indie 19.0.455.
Anyone having the same issue?
Network service crashed forerever
6822 14 5-
- Gagui
- 56 posts
- monomon
- 41 posts
I have the exact same problem, and have been having it in 18.5, too.
Found out it is a bug with Qt web engine, e.g. see https://github.com/qutebrowser/qutebrowser/issues/6235 [github.com]
Haven't found a solution, unfortunately.
I suspect it might be related to my environment, as the help seems to work on other machines.
- Gagui
- 56 posts
- Gagui
- 56 posts
- windwolfx23
- 12 posts
- dpotuznik
- 11 posts
- monomon
- 41 posts
- MirHadi
- 147 posts
- hudmike
- 73 posts
- pmcnagny
- 3 posts
- FJSam
- 18 posts
- Gagui
- 56 posts
- FJSam
- 18 posts
GaguiFJSsamHello,
Hope this helps anyone, I removed the desktop folder from documents/houdini19.5 folder and worked for me, needed to create new desktops after that though.
I've just tried that and the error keeps poping up.
I'm using 19.0.622
Ah, worked for me, try to rename the houdini19.5 folder to houdini19.5_old or something and start houdini, this should start a fresh houdini and create a new houdini19.5 folder there. If all is okay then there's something wrong with your houdini19.5 folder, I've found the desktop thing this way, maybe something else is creating your issue in that folder.
- Gagui
- 56 posts
FJSsam
I've already tried that and no luck. I have a clue the thing is causing this is the vray installation. If I unistall vray the error disappear. I've already wrote in chaos forum talking about the problem and other users have the same issue but for now they didn't find a solution.
Edited by Gagui - Aug. 9, 2022 04:49:06
- monomon
- 41 posts
