Time offset for instanced "references" not working (well)
   Views 2835   Replies 3   Subscribers 2
I'm using the instancer node with "reference" option to instance a bunch of animated references (not the "instancable reference" option due to buggy variants and disappearing geo), and need to offset the animations randomly. Cannot figure out a way though.
- The "retime instances"-node does not work if "reference" was selected in the instancer.
- Using a for-each loop with a "time shift"-node works but is extremely slow to use as it evaluates every frame.
- I'm also not able to use "edit property" to change the prototype "frame offset" in the reference node, as there is none in the USD schema.
I feel I am missing something obvious here? Is wrangle the way to go perhaps?
Edited by AndreasWeidman - Feb. 3, 2022 05:32:36
Andreas Weidman
VFX Supervisor - Dupe VFX
www.dupevfx.com
In the past, I have done this by making sure my animated instance was a mesh sequence. Then the task becomes constructing an s@instancefile attribute that references the files on disk. Each point can have its own temporal offset associated with it. Look that up inside the instancer, and construct your per-frame s@instancefile attribute based on that number and the current frame.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Interessting. Thank you.
However, I just discovered that this is a bug with 18.5. "instancable reference" work like a charm in 19 without buggy behavior. Does'nt solve my problem though as the show is using 18.5 so I'll look into it.
Andreas Weidman
www.dupevfx.com
Hello Andreas.
Any chance you would have a solution for time offseting pointinstancer instances?
