Difference between turn on "Create Packed Fragments"or not
2894 4 2-
- happybabywzy
- 144 posts
- cwhite
- 795 posts
I'd suggest reading https://www.sidefx.com/docs/houdini/model/packed.html [www.sidefx.com]
If the toggle is off, Packed Geometry primitives are created instead. Both will "work" but are optimized for different use cases: in your case, for fractured pieces you should be using packed fragment primitives.
- raincole
- 692 posts
- cwhite
- 795 posts
You probably only need to pack the proxy geometry going into the simulation, and transfer the motion to high-res geometry afterwards
I believe this is just a viewport limitation, though, as the materials are e.g. rendered in mantra if the Declare Materials parameter is configured to include all shaders in the scene
- happybabywzy
- 144 posts
cwhite
Thank You!
