Houdini Niagara Point Cache parameter
   Views 2338   Replies 2   Subscribers 2
Is is possible to set a Houdini Point Cache Niagara user parameter at runtime from blueprint?
I cannot find the matching 'Set Niagara Variable' function to do it.
-Gabor
Hey Gabor,
Have you found the solution to this issue?
Dealing with it at the moment and trying to see other possible solutions.
Thanks for your insight!
-Skawt
Hi Skawt,
It was a long time ago, but I don't think I did. Usually I use a workaround with VATs that you can process in Niagara.
-Gabor
