Hair/Fur issue, fur stick and stretch on collision objects
   1960   1   0
Hi guys, I have an issue when I simulate the fur with the collision object which is the skirt. Some of the furs are stuck on skirts and be stretched a lot. Super confused with it, is anyone had this issue before? Any advice will help a lot, thanks!
WeChat Image_20220312003418.png (143.4 KB)
If the furs is intersecting with the collision object at the beginning of the Sim then you will have the problem you are describing. That would be the first thing I would check
