i'm using the saveFrame()-method of the hou.IPRViewer class to save JPG-snapshots of the "Render View" to disk. Is there a way to bake in the current ACES-viewer-transform? Or one of the ACES output-transforms (ACES-CG -> Output sRGB)? I'd like the JPGs on disk, when viewed with a standard image viewer, to look like in the renderview? The saveFrame()-method has a "lut" argument, but it doesn't seem to do anything.
cheers,
Moritz.
hou.IPRViewer.saveFrame() + OCIO/ACES
1098 1 1- moritzg
- 3 posts
- ababak
- 7 posts
Hi Moritz,
Try to use it like this:
Andriy
ipr_viewer = hou.ui.paneTabOfType(hou.paneTabType.IPRViewer) if not ipr_viewer: return "" conv_lut = os.path.join( os.path.dirname(os.getenv("OCIO")), "baked", "houdini", "Rec.709 for ACEScg Houdini.lut", ).replace("\\", "/") ipr_viewer.saveFrame(path, 0, -1, -1, "C", "C", "*", conv_lut, 1.0, False)
Andriy
