Generated with tet embed a beautiful mesh
Your text to link here... [imgur.com]
I want to export it.
Asking some guidance to generate these two files:
mesh_nodes.txt contains the node coordinates
mesh_elements.txt contains the element node connectivity
Export tetrahedron nodes coordinates and connectivity
2369 1 1-
- davide445
- 54 posts
- davide445
- 54 posts
To give an example here [people.sc.fsu.edu] there are some test files (i.e. mesh3d) depicting how the two files need to be formatted.
Wanted to ask if anyone has the Python or Houdini SDK experience to understand how complex can be this activity and define a quotation for a consulting work.
As alternative path can be to map Houdini native .geo format into gmsh .msh [gmsh.info] format.
AMD Ryzen 5 2600X, 4x16GB 3200 Mhz, Kfa2 GTX 1070 EX 8GB, Windows 10 Pro, KDE Neon
