Deadline scheduler questions
   2035   2   1
Dear All,
I'm working on a TOP node that shuffles the order of the frames in a sequence and renders it in this shuffled order. (First the 'reference frames', while the rest of the frame list is 'binary diced'). I would like to render these frames on a Deadline farm. The logic is there, it works, renders the frames in this shuffled order, but I got two issues that stops me to enter the node into production:
1. Deadline shows the frame number wrong. On my work item both the `pdg_frame` and the `frame` attrib is set to the correct value. Yet Deadline Monitor seems to use the `index` for the frame number. I use the `index` attrib to force my render order, so that is obviously wrong. Is there a better way to force an arbitrary render order than using `index`? And/or is there a way to explicitly tell Deadline what frame number to display instead of `index`?
2. When I press MMB on the work items after generation I got: `Error: Unable to get Deadline task report due to lack of job or task id for this work item. Check Deadline Monitor.` After cooking I got: `Error: Unable to get Deadline task report for task 6 of job 624c2eccd06d632b88bdb8bb. Check Deadline Monitor.` After cooking it's also pretty slow to show the info window of the work item and this phenomenon makes Houdini pretty unstable. What do I do wrong here?
Do I miss some documentation that I need to read?
Thanks in advance,
Mate
I got the same problem, frame numbers always start from 0 on deadline. Changing the index attribute in topnet doesn't affect it.
Problem was with H 20, fixed in 20.5
