Geometry Import - Wedge Attribute
   2752   4   0
Hey y'all! Had a small roadblock and wanted to ask for some help. The goal is to get curves from Unreal to drive my terrain flattening/formation road tool, within my TOPS network. The issue I am having though is before even getting to unreal, and I am sure its just something dumb I am not seeing.
I've been following Kenny's Indie Gamedev tutorial series [www.sidefx.com] and am having an issue with the Geometry Import node not taking my Wedge attribute SOP path. The video I am getting issues on is the Multi-parms vid(#4)
I had noticed that Ari uses opinputpath in his geometry import tutorial [www.sidefx.com] but just wanted to ask if there was a proper method for me to go about.
Thanks so much for your help!
Edited by tourke - April 7, 2022 21:05:27
It's hard to say from screenshots what the problem is. Can you attach a .hip file that demonstrates the issue?
I had to recreate it, without my main network. But the error persists. Basically I can't call @curveasset on my geometry import node in the top network.
Thanks for taking the time to look through it! I appreciate you!
TopWedgeExample.7z (26.1 KB)
There are a few issues with your file. The first issue is that your expression has a typo -- it uses @curveassset but it should be @curvesasset instead. The second problem is that you're pointing the "SOP Path" parameter to an Object node, that contains another Object node. The path should really be pointed to a SOP instead -- `@curvesasset`/geo1 for example works as expected.
Just wanted to say thanks!
While that worked perfectly for my example project I sent in the 7zip file, it didn't work in my main network. With some slight troubleshooting based on what you had said, I added the output node to the path and it works fine for me now. So my final SOP path was: `@curvesasset`/geo1/output0
Really appreciate the help.
