I'm having an issue whilst trying to create a random walk algorithm purely within VEX. I have a single wrangle, and within that I've got a for loop that creates a point every iteration, as long as there is an available location. However it seems no matter what I try, the created points don't react to the previously created points, resulting in clipping or weird behaviour. I've tried debugging by creating a vector array attribute of all available locations for every created point, but they're always empty.
Is there something I'm missing?
Find attached a hip with a basic setup of what I'm trying to do. The end goal would be for a point to start at zero, and randomly walk either {0,0,1}, {0,0,-1}, {1,0,0} or {-1,0,0} WITHOUT clipping into other points, if it detects a collision, it moves down {0,-1,0}. I'd preferably want it to all happen on frame 0 as well since I want to make this into a procedural tool and drive the creation of other things.
Cant react to created points within a loop within a wrangle
1787 3 0- pidgyedits
- 11 posts
- raincole
- 539 posts
- pidgyedits
- 11 posts
- animatrix_
- 4729 posts
Depending on the functions you want to use, you can do that using arrays as you suggested. Functions like pcfind/pcopen will require actual 3d points in your geometry so if you can avoid using these, then you can do all of this in a single wrangle node.
