connect start-end point spline for smooth NURBS curve
   1521   1   0
HI guys.
I'm trying to create an uniform nurbs curve started by labs spiral that will be used as camera path for a looped animation.
The issue is the start/end point at the bottom that is not connected and fused and as result the start/end of the animation is not working properly.
Someone knows a way how to solve this problem?
Thank you.
hip file and screen attached
please ignore multiple edits that works for shaping the spline.
Edited by demonsd_miles17 - April 24, 2022 08:29:52
spline.hipnc (388.8 KB)
You could use an Ends SOP to close the curve with Close Rounded U and Preserve Shape U, then delete the last point and copy back the position of the points before the Ends SOP to get a smooth result back.
There's probably a better way, but maybe this already works for you?
spline.hipnc (396.2 KB)
