MaterialX mtlx mix BSDF node bug
   2100   5   1
Just wanted to see if nyone else has noticed a bug when mixing BSDFs with mtlx mix
when set to 0 it shows input1
and when set to 1 it also shows input 1
if you use a value of 0.001 it does show input0
this seems to occur specifically with the BSDF mode.
this makes shader building difficult. It seems when a constant is plugged in with the value of 0 the issue does not occur
would be great to see if anyone else has had this issue?
Best,
Rich
Edited by Hypershader - May 4, 2022 09:51:59
I'm seeing the same thing. It works fine when driven by inputs like your constant or a noise, but yeah, it seems like the Mix parameter on its own is borked.
I think there was a bug that was recently fixed for nodes with inputs at default values not triggering an update.
Can you send me over the release note describing the fix please?
Hypershader
Fixed a bug with retranslating a shader node parameter when it's set back to adefaule value, which would not get reflected in the USD shader on the stage.
Wed. April 27, 2022
jsmack
Hypershader
Wed. April 27, 2022
I guess it hasn't been backported
