Unity Tree Prototype using for-loop
   2250   0   0
Hello!
How should I go about assigning the value to multiple "s@unity_hf_tree_prototype" inside a for-loop? I basically want to make something like:
for(int x = 0; x < ch("XXX"); x++)
     s@unity_hf_tree_prototype[x] = ch("parameter[x]");
where the value of x is the one from the for-loop, but the tree_prototype function doesn't work as a list, so I don't know how to reference the i value at the end of that function.
* ch("XXX") is going to be a multiparm list folder and ch("parameter") should be string parameters created inside that folder.
The number has to be decided in the UI, so I don't know how many instances need to exist, hence why I have to use a for-loop.
Edited by radumitroi95 - May 6, 2022 12:22:25
