Cloth Capture custom weights
   1312   2   0
Hi everyone. Does anyone know if it is possible to adjust or create custom weights to use with cloth deform ? I can't understand what clothCapture attr type is. Point deform is easy. There is an array of points and array of weights so you can modify or create your own but for the cloth capture it's something different and I can't figure out what that is and if it's even possible to modify it.
Thanks.
Same workflow as here [www.sidefx.com]
FX Supervisor
Method Studios, NY
Holy moly. Thank you. That's exactly what I needed.
