How do I fix Permissions error?
1375 1 1- thenudepresident
- 3 posts
I am trying to create a Vellum soft body network by using the Vellum shelf. Every time I select my geo I want to use for the soft body I get an "Failed to modify node or parameter because of a permission error.", and I've also attached a screenshot of the full error. This error occurs with pretty much every sort of DOP network, Particles, Grains, Vellum, RDBs, etc.
- staicu.teodor.23
- 12 posts
this occurs with heightfields as well. can we get an official answer on this, sidefx?
EDIT: quote from sidefx "try resetting your Houdini to it's defaults by renaming your $HOME/houdini20.0 directory to houdini20.0_OLD.
When you relaunch Houdini this directory will be regenerated, with all your Houdini settings at default."
tried and it works
tried and it works
Edited by staicu.teodor.23 - March 4, 2024 11:23:39
