Point attrib to Node name set. ( Python)
   1572   3   0
Hey there.
I have a question
1.) I am trying to take a pointcloud with a string name attribute, and then I want to create a geo node per point,
2.) extract the path attribute from the point and feed it into a parm on that newly created node
3.) set node name to the name in the attribute as well
3.) in python.
import hou
sel = hou.selectedNodes()
createWorkArea = hou.node("/obj").createNode("subnet", "workArea")
for node in sel:
    geo = node.geometry()
    points = geo.iterPoints()
    for point in geo.points():
        Path = geo.findPointAttrib("name")
        FullPathAttrib = point.attribValue(Path)
        createGeoNode = createWorkArea.createNode("geo", "geoNode")
        #############The line below is causing issues.
        createGeoNode.setName(FullPathAttrib)
        AttribParm = createGeoNode.parm("some parm here")
        AttribParm.set(FullPathAttrib)
So I got the parm set portion working, the creation of the nodes is ok. but the setting the names of the nodes not so much.
What am I doing wrong?
EDIT: I also tried this in the problematic node. didn't work either.
createGeoNode.setName('' + str(FullPathAttrib))
Any help would be appreciated.
Edited by Martin Krol - June 1, 2022 15:22:21
createNode allows you to set node name, so I guess you can set the name there instead of writing another line to set name?
        createGeoNode = createWorkArea.createNode("geo", FullPathAttrib) ##########TRY THIS?
        ####createGeoNode.setName(FullPathAttrib)
"is causing issues" and "not working" is a very vague description
are you getting any specific error?
if your are for example getting "Invalid Name" error make sure that the name attribute on all the points is a valid name, so no invalid characters like space or / etc...
FX Supervisor
Method Studios, NY
Thanks guys.
So, for whatever reason using node.setName(str(someDeclaredVariable))
was giving me the following error:
hou.NetworkMovableItem_setName(self, name, unique_name)
OperationFailed:the attempted operation failed.
However, I did as hinsunlee suggested. I wrote str(someDeclaredVariable)) into the name section when creating the node and not as a separate line, and it worked out .
so what worked was changing this line
into this
createGeoNode = createWorkArea.createNode("geo", str(fullPathAttrib))
Cheers.
