reversefoot sop not work correctly
1801
3
0
- raistlinf
- 19 posts
Reversefoot sop throws an error in last buids of houdini.
But in 19.0.383 Reversefoot work correctly.
Edited by raistlinf - June 16, 2022 03:48:10
ReverseFootError.hipnc (180.2 KB)
- willh
- 134 posts
if you use the roll parameter it seems to work fine, the controls however seems to be broken.
You should send in a bug report
- willh
- 134 posts
Here is how you can set up your own custom one
its pretty straight forward
CustomReverseFoot.hipnc (217.6 KB)
- mihneas
- 51 posts
Thanks for pointing this out. This has been fixed and should appear so in the next daily build.
