Hi, I was following this tutorial and I'm done with the procedural fencing. Now I want to create really big fencing inside the unity where ever I just click using curve it should create the fencing I don't know which parameter I need to expose in order to do that.
Tutorial Link - Your text to link here... [www.youtube.com]
Here is the screenshot I can control the height but don't know how to draw the curve inside unity.
Curve tool edit inside Unity?
1545 1 0- Threye21
- 11 posts
- Threye21
- 11 posts
I figured it out - your sop curve should be an older one (Like Curve, not 2.0 ) {If you can't see the curve Go to asset > Asset definition Toolbar show always} and it should be set to the polygon.
While exporting follow this as well Node> EditableNode > select curve
Edited by Threye21 - Aug. 2, 2022 08:10:34
