Startup warning: Viewer state type conflict
   4186   11   3
Hi Everyone!
I've been experiencing the following warning on startup in the Console since the last few builds:
= = = Resources registration = = =
Viewer state type conflict: labs::ruler
Conflicting viewer state: C:/Users/xxxxx/Documents/houdini19.0/SideFXLabs/19.0.659/SideFXLabs19.0/viewer_states/ruler.py
Colliding with: C:/Program Files/Side Effects Software/sidefx_packages/SideFXLabs19.0/viewer_states/ruler.py
Viewer state type conflict: viewportmeasuretool
Conflicting viewer state: C:/Users/xxxxx/Documents/houdini19.0/SideFXLabs/19.0.659/SideFXLabs19.0/viewer_states/viewportmeasuretool.py
Colliding with: C:/Program Files/Side Effects Software/sidefx_packages/SideFXLabs19.0/viewer_states/viewportmeasuretool.py
Clearly it has something to do with duplicate python files. Does anybody know which one is safe to delete?
Thank you.
I think you have two installs of labs. The one in your documents folder is probably the older one, since the launcher now installs labs in the launcher folder.
jsmack
That's what I thought but chickened out on acting on it. Thank you!
I'm getting a similar message with 19.5, except it looks like it's colliding with itself?
Conflicting viewer state: C:/Program Files/Side Effects Software/sidefx_packages/SideFXLabs19.5/viewer_states/viewportmeasuretool.py
Colliding with: C:/Program Files/Side Effects Software/sidefx_packages/SideFXLabs19.5/viewer_states/viewportmeasuretool.py
Im getting this too in 19.5.303
For me its all the kinefx stuff colliding with itself.
Edited by dunnieboy - Aug. 5, 2022 09:37:41
Does anyone know how to fix this?
this issue is freezing my software.
Same happening here. I tried 19.5.303 and 19.5.349.
Conflicting viewer state: C:/Program Files/Side Effects Software/sidefx_packages/SideFXLabs19.5/viewer_states/ruler.py
Colliding with: C:/Program Files/Side Effects Software/sidefx_packages/SideFXLabs19.5/viewer_states/ruler.py
dunnieboy
Try installing python 3.7 version of 19.5.303. That removed all the kinefx errors for me but I'm still getting errors of 'Viewer state type conflict: viewportmeasuretool' and 'Viewer state type conflict: labs::ruler'
Edit. The stream of errors came back again.
Edited by proceduralist - Aug. 22, 2022 10:32:48
Any further update on this? I'm seeing the same self collision thing thing in 19.5.303.
christopher_lemon
Same happening with me. Tried installing and running Houdini 19.5.352 but still the same issue.
I added a fix for the next 19.5 daily build. It looked like these type conflicts were wrong, although I wasn't able to reproduce them. The fix should avoid reporting false type conflicts.
mabelzile
Thanks a lot! No errors popping up in 19.5.355.
