OD Shelf Tools 2021 does not work in H19.5 :(
   3519   3   2
Hi guys just wanted to report that OD Shelf Tools 2021 is not working in Houdini 19.5 tested on the x86 and AS mac builds on an m1 max. Hopefully Origami Digital is working on an update. Specifically the asset library crashes houdini every time. Has any one been successful in getting it to work?
check that your preferences are all correct, meaning, possibly you copied some things from your 19.0 to 19.5 installation and missed things.. But its all working.
Btw. fastest support times will be on the dediated discord server (which you can get to under the main odtools/help menu.
Oliver Hotz
Origami Digital
Author of ODTools for Houdini: https://origamidigital.com/cart/index.php?route=product/product&path=59_63&product_id=66 [origamidigital.com]
seems the issue stems from the PIL module shipping with Houdini OSX isnt properly compiled. This is the same Issue on windows Houdini 19.5 py 3.7 python build. The Houdini 19.5 py3.9 build works fine on windows.
Oliver Hotz
Origami Digital
i wrote a RFE ticket. can confirm that the Py39 version is working.
www.enoni.de
