How to copy position like Attribute Copy but in KineFX
   1247   3   2
I'd like to copy the position (P) of some points onto some root joints with the same i@id.
It copies it, but all the children don't move along like in the Rig Pose.
How can I make it so that the children move with it?
Hip file included.
Thanks in advance.
question_copy_rigs.hiplc (245.0 KB)
Whoops just isolating the points and setting a Skeleton Blend to 1 does it. Don't know if it's the fastest but it works.
Screenshot 2022-07-22 at 09.24.11.png (1.4 MB)
FWIW, I think using Skeleton Blend is the best way. Sorry, I don't have access to Houdini right now but in 19.5, I thought it has a way to only blend a specific group of points so I don't think you need the added steps of first isolating the points you want to copy.
I think for root positions the most "idiomatic" way for Kinefx is Compute Transform SOP after modifying. At least you won't need two streams with it.
So in your case you can use it with Compute World From Local mode and @name=*rootfor Constrained Group
