I have a mesh and have a few separate Vellum sims that fire in a linear fashion. I've found I need to "stash" the output of the first vellum sim, otherwise the 2nd vellum sim runs forever. As result there is a bunch of manual updates I want to remove in the graph to have it cook and update properly.
Upstream I want to update a rigpose node and have all the stashes update and sims fire on the new data.
I am not having any luck getting both the stash nodes to updates.. I have tried python sops before and after the stash with hou.node("../stash1").parm("stashinput").pressButton()
and I have tried
n = hou.node("../stash1")
parm = n.parm("stash")
parm.set(geo) without much luck.
I am under the impression that the stash node might need a time update to trigger, but have not been able to make a timeshift force an update either.
Thanks for any help.
Force Stash node to update on upstream changes
1884 4 2- kfinlayson
- 9 posts
- jsmack
- 8041 posts
- kfinlayson
- 9 posts
- vinyvince
- 275 posts
This stash bug is still there, it does have serious issues to update and it is just unreliable. A fix will be welcomed
I have noticed before the new cacheif which looks cool, but hasn't seen or read much about it, are you guys tried it?
Vincent Thomas (VFX and Art since 1998)
Senior Env and Lighting artist & Houdini generalist & Creative Concepts
http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
- vinyvince
- 275 posts
In my case, the issue came as i have a stash node instanciated... Lucky in my case, i could easily avoid this situation
