Hi, I'm wondering how we can change the setting for the default purpose shown in a viewport. Our trees systematically have a rig that come as guides. Everytime we open houdini the default purpose displayed are proxy and guides. We have to manually uncheck guides other wise it's super heavy. Is there a way to change the default setting so it only display the proxy? Thank you.
Change default purpose setting in viewport
1574 2 1- Manuel Gaudreau
- 9 posts
- mtucker
- 4525 posts
The default purposes are set on a per-renderer basis in the UsdRenderers.json files found in your HOUDINI_PATH. For Houdini GL in particular, $HFS/houdini/UsdRenderers.json contains:
You can copy the block that describes Houdini GL to a new UsdRenderers.json file in a higher priority location in your HOUDINI_PATH to override these default purposes.
{ "HD_HoudiniRendererPlugin" : { ... "defaultpurposes" : [ "guide", "proxy" ], ... }, ... }
- Manuel Gaudreau
- 9 posts
