Hello everyone!
I would like to know if there is any way to compute eigenvectors for a given matrix via VEX.
There is a VEX function called eigenvalues but as its name suggests it only calculates eigenvalues, not eigenvectors!
Any help would greatly be appreciated!
Calculating eigen vectors for a given matrix with VEX
3419 7 1- N-G
- 209 posts
- N-G
- 209 posts
- Robbert
- 55 posts
Not really a VEX solution, but a solution anyway; if you have python modules configured and numpy installed you could store 3x3 matrices on points and feed those into a python SOP. Then iterate over those points and use the numpy / linear algebra functions to convert into eigenvalues and eigenvectors that you then write back to those points.
I basically just implemented the explanation on this page [web.physics.utah.edu] in a python SOP. The matrix here is a 3x3 matrix stored in the 'covariance' attribute.
Here are two other sources that helped me out;
https://www.visiondummy.com/2014/04/geometric-interpretation-covariance-matrix/ [www.visiondummy.com]
https://houdinigubbins.wordpress.com/2017/06/07/covariance-matrix/ [houdinigubbins.wordpress.com]
import numpy as np from numpy import linalg as LA node = hou.pwd() geo = node.geometry() points = geo.points() for point in points: m = point.attribValue("covariance") arr = np.asarray(m) mm = arr.reshape(3,3) w, v = LA.eig(mm) point.setAttribValue("eigenvalues",w) point.setAttribValue("xeigenvector",v[:,0]) point.setAttribValue("yeigenvector",v[:,1]) point.setAttribValue("zeigenvector",v[:,2])
Technical VFX artist @ Housemarque / Sony Interactive Entertainment
- N-G
- 209 posts
- animatrix_
- 4730 posts
N-G
Thanks a lot, man!
I'm just curious to know why SideFX doesn't add the eigenvector function to VEX!
VEX have svddecomp (singular value decomposition). I posted an example of it here:
https://www.sidefx.com/forum/topic/84345/#post-364636 [www.sidefx.com]
This is one of the topics I plan to cover in Pragmatic VEX: Volume 2.
- N-G
- 209 posts
animatrix_N-G
Thanks a lot, man!
Thanks a lot, dear @animatrix.
I am in doubt if SVD decomposition can yield eigenvectors of a matrix, instead, it gives eigenvectors for matrix times transpose of the matrix!
- animatrix_
- 4730 posts
N-Ganimatrix_N-G
Thanks a lot, man!
Sorry I didn't see your reply but for the record:
If your matrix is symmetric, you can use diagonalizesymmetric which computes the eigenvalue decomposition of a symmetric matrix: which is guaranteed to have a real spectrum. VEX doesn't have eigenvalue decompositions for general matrices since they would require complex numbers.
There is also eigenvalues VEX function that predates diagonalizesymmetric:
https://www.sidefx.com/docs/houdini/vex/functions/eigenvalues.html [www.sidefx.com]
There is an RFE to support non-symmetric matrices for eigenvalue decomposition: #132742. So feel free to bump that up if you want to see it in a future version of Houdini.
- N-G
- 209 posts
