USDImport cannot load default variant lod mesh?
   811   0   0
def Xform "ISMBP"
        matrix4d xformOp:transform = ( (1, -0, 0, 0), (0, 1, -0, 0), (0, 0, 1, 0), (-356, -231, 0, 1) )
        uniform token[] xformOpOrder = ["xformOp:transform"]
        def Xform "InstancedStaticMesh"
            matrix4d xformOp:transform = ( (1, -0, 0, 0), (0, 1, -0, 0), (0, 0, 1, 0), (0, -0, -1, 1) )
            def PointInstancer "ISMInstance"
                quath[] orientations.timeSamples = {
                    3.4028234663852886e38: [(1, -0, 0, -0), (1, 0, -0, -0), (1, 0, -0, -0)],
                point3f[] positions.timeSamples = {
                    3.4028234663852886e38: [(0, -0, 0), (0, -200, 0), (0, 200, 0)],
                int[] protoIndices.timeSamples = {
                    3.4028234663852886e38: [0, 0, 0],
                prepend rel prototypes = </Root/ISMBP/InstancedStaticMesh/ISMInstance/Prototypes/SM_Box>
                float3[] scales.timeSamples = {
                    3.4028234663852886e38: [(1, 1, 1), (1, 1, 1), (1, 1, 1)],
                def Scope "Prototypes"
                    def "SM_Box" (
                        prepend references = @Assets/Game/Environment_Set/MedievalKingdom/Content/Models/Props/Props_1/SM_Box.usda@
My usda file is like above,i can load PointInstancer "ISMInstance" in solaris stage by sublayer, but in sop i use usdimport the PointInstancer "ISMInstance" cannot be loaded, by test, i found the reason is my SM_Box has variant mesh lod like following:
def "SM_Box" (
    assetInfo = {
        asset identifier = @D:\PanGu2020\PanGu\USDTest\Assets\Game\Environment_Set\MedievalKingdom\Content\Models\Props\Props_1\SM_Box.usda@
        string name = "SM_Box"
    variants = {
        string LOD = "LOD0"
    prepend variantSets = "LOD"
    variantSet "LOD" = {
        "LOD0" {
            def Mesh "LOD0"
                int[] faceVertexCounts = [3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3]
                int[] faceVertexIndices = [0, 1, 2, 1, 3, 2, 4, 5, 6, 5, 7, 6, 8, 9, 10, 9, 11, 10, 12, 13, 14, 13, 15, 14, 16, 17, 18, 17, 19, 18, 20, 21, 22, 21, 23, 22, 24, 25, 26, 25, 27, 26, 28, 29, 30, 29, 31, 30, 32, 33, 34, 33, 35, 34, 36, 37, 38, 37, 39, 38, 40, 41, 42, 41, 43, 42, 44, 45, 46, 45, 47, 46, 48, 49, 50, 49, 51, 50, 52, 53, 54, 53, 55, 54, 56, 57, 58, 57, 59, 58, 60, 61, 62, 61, 63, 62, 64, 65, 66, 65, 67, 66, 68, 69, 70, 69, 71, 70, 72, 73, 74, 73, 75, 74, 76, 77, 78, 77, 79, 78, 80, 81, 82, 81, 83, 82, 84, 85, 86, 85, 87, 86, 88, 89, 90, 89, 91, 90, 92, 93, 94, 93, 95, 94, 96, 97, 98, 97, 99, 98, 100, 101, 102, 101, 103, 102, 104, 105, 106, 105, 107, 106, 108, 109, 110, 109, 111, 110, 112, 113, 114, 113, 115, 114, 116, 117, 118, 117, 119, 118, 120, 121, 122, 121, 123, 122, 124, 125, 126, 125, 127, 126, 128, 129, 130, 129, 131, 130, 132, 133, 134, 133, 135, 134, 136, 137, 138, 137, 139, 138, 140, 141, 142, 141, 143, 142, 144, 145, 146, 145, 147, 146, 148, 149, 150, 149, 151, 150, 152, 153, 154, 153, 155, 154, 156, 157, 158, 157, 159, 158, 160, 161, 162, 161, 163, 162, 164, 165, 166, 165, 167, 166, 168, 169, 170, 169, 171, 170, 172, 173, 174, 173, 175, 174, 176, 177, 178, 177, 179, 178, 180, 181, 182, 181, 183, 182, 184, 185, 186, 185, 187, 186, 188, 189, 190, 189, 191, 190, 192, 193, 194, 193, 195, 194, 196, 197, 198, 197, 199, 198, 200, 201, 202, 201, 203, 202, 204, 205, 206, 205, 207, 206, 208, 209, 210, 209, 211, 210, 212, 213, 214, 213, 215, 214, 216, 217, 218, 217, 219, 218, 220, 221, 222, 221, 223, 222, 224, 225, 226, 225, 227, 226, 228, 229, 230, 229, 231, 230, 232, 233, 234, 233, 235, 234, 236, 237, 238, 237, 239, 238, 240, 241, 242, 241, 243, 242, 244, 245, 246, 245, 247, 246, 248, 249, 250, 249, 251, 250, 252, 253, 254, 253, 255, 254, 256, 257, 258, 257, 259, 258, 260, 261, 262, 261, 263, 262, 264, 265, 266, 265, 267, 266, 268, 269, 270, 269, 271, 270, 272, 273, 274, 273, 275, 274, 276, 277, 278, 277, 279, 278, 280, 281, 282, 281, 283, 282, 284, 285, 286, 285, 287, 286]
                normal3f[] normals = [(0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (0, -0, 1), (0, -0, 1), (0, -0, 1), (0, -0, 1), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (-0.70866144, -0, 0.70866144), (-0.70866144, -0, 0.70866144), (-0.70866144, -0, 0.70866144), (-0.70866144, -0, 0.70866144), (0.70866144, -0, -0.70866144), (0.70866144, -0, -0.70866144), (0.70866144, -0, -0.70866144), (0.70866144, -0, -0.70866144), (0, -0, 1), (0, -0, 1), (0, -0, 1), (0, -0, 1), (0, -0.70866144, -0.70866144), (0, -0.70866144, -0.70866144), (0, -0.70866144, -0.70866144), (0, -0.70866144, -0.70866144), (0, 0.70866144, 0.70866144), (0, 0.70866144, 0.70866144), (0, 0.70866144, 0.70866144), (0, 0.70866144, 0.70866144), (0.70866144, -0, 0.70866144), (0.70866144, -0, 0.70866144), (0.70866144, -0, 0.70866144), (0.70866144, -0, 0.70866144), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-0.70866144, -0, -0.70866144), (-0.70866144, -0, -0.70866144), (-0.70866144, -0, -0.70866144), (-0.70866144, -0, -0.70866144), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, 0.70866144, -0.70866144), (0, 0.70866144, -0.70866144), (0, 0.70866144, -0.70866144), (0, 0.70866144, -0.70866144), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0.70866144, 0.70866144), (0, -0.70866144, 0.70866144), (0, -0.70866144, 0.70866144), (0, -0.70866144, 0.70866144), (-0.70866144, -0.70866144, 0), (-0.70866144, -0.70866144, 0), (-0.70866144, -0.70866144, 0), (-0.70866144, -0.70866144, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0.70866144, 0.70866144, 0), (0.70866144, 0.70866144, 0), (0.70866144, 0.70866144, 0), (0.70866144, 0.70866144, 0), (0.70866144, -0.70866144, 0), (0.70866144, -0.70866144, 0), (0.70866144, -0.70866144, 0), (0.70866144, -0.70866144, 0), (-0.7007874, 0.70866144, 0), (-0.7007874, 0.70866144, 0), (-0.7007874, 0.70866144, 0), (-0.7007874, 0.70866144, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-0.007874016, 0.007874016, 1), (-0.007874016, -0.007874016, 1), (-0.007874016, 0.007874016, 1), (-0.007874016, -0.007874016, 1), (-0.007874016, -0.007874016, 1), (0.007874016, -0.007874016, 1), (-0.007874016, -0.007874016, 1), (0.007874016, -0.007874016, 1), (0.007874016, -0.007874016, 1), (0.007874016, 0.007874016, 1), (0.007874016, -0.007874016, 1), (0.007874016, 0.007874016, 1), (0.007874016, 0.007874016, 1), (-0.007874016, 0.007874016, 1), (0.007874016, 0.007874016, 1), (-0.007874016, 0.007874016, 1), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0, -0, 1), (0, -0, 1), (0, -0, 1), (0, -0, 1), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, -0, 1), (0, -0, 1), (0, -0, 1), (0, -0, 1), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -0, 1), (0, -0, 1), (0, -0, 1), (0, -0, 1), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -0, 1), (0, -0, 1), (0, -0, 1), (0, -0, 1), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0)]
                point3f[] points = [(-44.046192, 46.11, 6.038819), (-44.046192, 46.11, 94.13118), (44.046192, 46.11, 6.038819), (44.046192, 46.11, 94.13118), (-46.10997, -44.04618, 6.038819), (-46.10997, -44.04618, 94.13118), (-46.10997, 44.04618, 6.038819), (-46.10997, 44.04618, 94.13118), (-44.046192, -44.04618, 96.195), (44.046192, -44.04618, 96.195), (-44.046192, 44.04618, 96.195), (44.046192, 44.04618, 96.195), (46.10997, -44.04618, 94.13118), (46.10997, -44.04618, 6.038819), (46.10997, 44.04618, 94.13118), (46.10997, 44.04618, 6.038819), (44.046192, -44.04618, 3.9750009), (-44.046192, -44.04618, 3.9750009), (44.046192, 44.04618, 3.9750009), (-44.046192, 44.04618, 3.9750009), (-44.046192, -46.11, 6.038819), (44.046192, -46.11, 6.038819), (-44.046192, -46.11, 94.13118), (44.046192, -46.11, 94.13118), (34.39592, -46.11, 93.90641), (-43.821423, -46.11, 15.6891), (34.39592, -48.8925, 93.90641), (-43.821423, -48.8925, 15.6891), (-34.39592, -46.11, 6.2635803), (43.821423, -46.11, 84.48089), (-34.39592, -48.8925, 6.2635803), (43.821423, -48.8925, 84.48089), (-43.821423, 34.3959, 98.9775), (34.39592, -43.821423, 98.9775), (-34.39592, 43.821423, 98.9775), (43.821423, -34.3959, 98.9775), (46.10997, -43.821423, 84.48089), (46.10997, 34.3959, 6.263581), (48.89246, -43.821423, 84.48089), (48.89246, 34.3959, 6.263581), (46.10997, 43.821423, 15.6891), (46.10997, -34.3959, 93.90641), (48.89246, 43.821423, 15.6891), (48.89246, -34.3959, 93.90641), (-33.13435, 46.11, 92.644844), (42.55986, 46.11, 16.95067), (-33.13435, 48.8925, 92.644844), (42.55986, 48.8925, 16.95067), (-48.89246, -34.3959, 6.263581), (-48.89246, -43.821423, 15.6891), (-48.89246, 43.821423, 84.48089), (-48.89246, 34.3959, 93.90641), (33.13435, 46.11, 7.52515), (-42.55986, 46.11, 83.21933), (33.13435, 48.8925, 7.52515), (-42.55986, 48.8925, 83.21933), (-43.821423, -48.8925, 15.6891), (-34.39592, -48.8925, 6.2635803), (34.39592, -48.8925, 93.90641), (43.821423, -48.8925, 84.48089), (-46.10997, 43.821423, 84.48089), (-46.10997, -34.3959, 6.263581), (-48.89246, 43.821423, 84.48089), (-48.89246, -34.3959, 6.263581), (-43.75602, -33.56821, 1.192499), (34.41188, 43.799732, 1.192499), (-34.41188, -43.799732, 1.192499), (43.843033, 34.37983, 1.192499), (-46.10997, -43.821423, 15.6891), (-46.10997, 34.3959, 93.90641), (-48.89246, -43.821423, 15.6891), (-48.89246, 34.3959, 93.90641), (-43.821423, 34.3959, 96.195), (34.39592, -43.821423, 96.195), (-43.821423, 34.3959, 98.9775), (34.39592, -43.821423, 98.9775), (48.89246, 34.3959, 6.263581), (48.89246, 43.821423, 15.6891), (48.89246, -43.821423, 84.48089), (48.89246, -34.3959, 93.90641), (43.821423, -34.3959, 96.195), (-34.39592, 43.821423, 96.195), (43.821423, -34.3959, 98.9775), (-34.39592, 43.821423, 98.9775), (43.843033, 34.37983, 3.9750009), (-34.41188, -43.799732, 3.9750009), (43.843033, 34.37983, 1.192499), (-34.41188, -43.799732, 1.192499), (-43.75602, -33.56821, 3.9750009), (34.41188, 43.799732, 3.9750009), (-43.75602, -33.56821, 1.192499), (34.41188, 43.799732, 1.192499), (42.55986, 48.8925, 16.95067), (33.13435, 48.8925, 7.52515), (-33.13435, 48.8925, 92.644844), (-42.55986, 48.8925, 83.21933), (50, 50, -0.000008146034), (-50, 50, -0.000008146034), (36.25201, 50.085003, 13.833), (-36.25201, 50.085003, 13.833), (-50, 50, -0.000008146034), (-50, 50.00002, 99.99999), (-36.25201, 50.085003, 13.833), (-36.25201, 50.085003, 86.33699), (-50, 50.00002, 99.99999), (50, 50.00002, 99.99999), (-36.25201, 50.085003, 86.33699), (36.25201, 50.085003, 86.33699), (50, 50.00002, 99.99999), (50, 50, -0.000008146034), (36.25201, 50.085003, 86.33699), (36.25201, 50.085003, 13.833), (-50, 50, -0.000008146034), (-50, -50, 0.000008146034), (-50.08499, 36.252003, 13.833), (-50.08499, -36.252003, 13.833), (-50, -50, 0.000008146034), (-50, -49.999985, 100.000015), (-50.08499, -36.252003, 13.833), (-50.08499, -36.252003, 86.33699), (-50, -49.999985, 100.000015), (-50, 50.00002, 99.99999), (-50.08499, -36.252003, 86.33699), (-50.08499, 36.252003, 86.33699), (-50, 50.00002, 99.99999), (-50, 50, -0.000008146034), (-50.08499, 36.252003, 86.33699), (-50.08499, 36.252003, 13.833), (-50, 50.00002, 99.99999), (-50, -49.999985, 100.000015), (-36.25201, 36.252003, 100.170006), (-36.25201, -36.252003, 100.170006), (-50, -49.999985, 100.000015), (50, -49.999985, 100.000015), (-36.25201, -36.252003, 100.170006), (36.25201, -36.252003, 100.170006), (50, -49.999985, 100.000015), (50, 50.00002, 99.99999), (36.25201, -36.252003, 100.170006), (36.25201, 36.252003, 100.170006), (50, 50.00002, 99.99999), (-50, 50.00002, 99.99999), (36.25201, 36.252003, 100.170006), (-36.25201, 36.252003, 100.170006), (50, 50.00002, 99.99999), (50, -49.999985, 100.000015), (50.08499, 36.252003, 86.33699), (50.08499, -36.252003, 86.33699), (50, -49.999985, 100.000015), (50, -50, 0.000008146034), (50.08499, -36.252003, 86.33699), (50.08499, -36.252003, 13.833), (50, -50, 0.000008146034), (50, 50, -0.000008146034), (50.08499, -36.252003, 13.833), (50.08499, 36.252003, 13.833), (50, 50, -0.000008146034), (50, 50.00002, 99.99999), (50.08499, 36.252003, 13.833), (50.08499, 36.252003, 86.33699), (50, 50, -0.000008146034), (50, -50, 0.000008146034), (36.25201, 36.252003, -5.3421286e-13), (36.25201, -36.252003, 5.3421286e-13), (50, -50, 0.000008146034), (-50, -50, 0.000008146034), (36.25201, -36.252003, 5.3421286e-13), (-36.25201, -36.252003, 5.3421286e-13), (-50, -50, 0.000008146034), (-50, 50, -0.000008146034), (-36.25201, -36.252003, 5.3421286e-13), (-36.25201, 36.252003, -5.3421286e-13), (-50, 50, -0.000008146034), (50, 50, -0.000008146034), (-36.25201, 36.252003, -5.3421286e-13), (36.25201, 36.252003, -5.3421286e-13), (-50, -49.999985, 100.000015), (-50, -50, 0.000008146034), (-36.25201, -50.085003, 86.33699), (-36.25201, -50.085003, 13.833), (-50, -50, 0.000008146034), (50, -50, 0.000008146034), (-36.25201, -50.085003, 13.833), (36.25201, -50.085003, 13.833), (50, -50, 0.000008146034), (50, -49.999985, 100.000015), (36.25201, -50.085003, 13.833), (36.25201, -50.085003, 86.33699), (50, -49.999985, 100.000015), (-50, -49.999985, 100.000015), (36.25201, -50.085003, 86.33699), (-36.25201, -50.085003, 86.33699), (-36.25201, -50.085003, 86.33699), (-36.25201, -50.085003, 13.833), (-36.25201, -46.11, 86.33699), (-36.25201, -46.11, 13.833), (-36.25201, -50.085003, 13.833), (36.25201, -50.085003, 13.833), (-36.25201, -46.11, 13.833), (36.25201, -46.11, 13.833), (36.25201, -50.085003, 13.833), (36.25201, -50.085003, 86.33699), (36.25201, -46.11, 13.833), (36.25201, -46.11, 86.33699), (36.25201, -50.085003, 86.33699), (-36.25201, -50.085003, 86.33699), (36.25201, -46.11, 86.33699), (-36.25201, -46.11, 86.33699), (36.25201, 36.252003, -5.3421286e-13), (36.25201, -36.252003, 5.3421286e-13), (36.25201, 36.252003, 3.9750009), (36.25201, -36.252003, 3.9750009), (36.25201, -36.252003, 5.3421286e-13), (-36.25201, -36.252003, 5.3421286e-13), (36.25201, -36.252003, 3.9750009), (-36.25201, -36.252003, 3.9750009), (-36.25201, -36.252003, 5.3421286e-13), (-36.25201, 36.252003, -5.3421286e-13), (-36.25201, -36.252003, 3.9750009), (-36.25201, 36.252003, 3.9750009), (-36.25201, 36.252003, -5.3421286e-13), (36.25201, 36.252003, -5.3421286e-13), (-36.25201, 36.252003, 3.9750009), (36.25201, 36.252003, 3.9750009), (50.08499, 36.252003, 86.33699), (50.08499, -36.252003, 86.33699), (46.10997, 36.252003, 86.33699), (46.10997, -36.252003, 86.33699), (50.08499, -36.252003, 86.33699), (50.08499, -36.252003, 13.833), (46.10997, -36.252003, 86.33699), (46.10997, -36.252003, 13.833), (50.08499, -36.252003, 13.833), (50.08499, 36.252003, 13.833), (46.10997, -36.252003, 13.833), (46.10997, 36.252003, 13.833), (50.08499, 36.252003, 13.833), (50.08499, 36.252003, 86.33699), (46.10997, 36.252003, 13.833), (46.10997, 36.252003, 86.33699), (-36.25201, 36.252003, 100.170006), (-36.25201, -36.252003, 100.170006), (-36.25201, 36.252003, 96.195), (-36.25201, -36.252003, 96.195), (-36.25201, -36.252003, 100.170006), (36.25201, -36.252003, 100.170006), (-36.25201, -36.252003, 96.195), (36.25201, -36.252003, 96.195), (36.25201, -36.252003, 100.170006), (36.25201, 36.252003, 100.170006), (36.25201, -36.252003, 96.195), (36.25201, 36.252003, 96.195), (36.25201, 36.252003, 100.170006), (-36.25201, 36.252003, 100.170006), (36.25201, 36.252003, 96.195), (-36.25201, 36.252003, 96.195), (-50.08499, 36.252003, 13.833), (-50.08499, -36.252003, 13.833), (-46.10997, 36.252003, 13.833), (-46.10997, -36.252003, 13.833), (-50.08499, -36.252003, 13.833), (-50.08499, -36.252003, 86.33699), (-46.10997, -36.252003, 13.833), (-46.10997, -36.252003, 86.33699), (-50.08499, -36.252003, 86.33699), (-50.08499, 36.252003, 86.33699), (-46.10997, -36.252003, 86.33699), (-46.10997, 36.252003, 86.33699), (-50.08499, 36.252003, 86.33699), (-50.08499, 36.252003, 13.833), (-46.10997, 36.252003, 86.33699), (-46.10997, 36.252003, 13.833), (36.25201, 50.085003, 13.833), (-36.25201, 50.085003, 13.833), (36.25201, 46.11, 13.833), (-36.25201, 46.11, 13.833), (-36.25201, 50.085003, 13.833), (-36.25201, 50.085003, 86.33699), (-36.25201, 46.11, 13.833), (-36.25201, 46.11, 86.33699), (-36.25201, 50.085003, 86.33699), (36.25201, 50.085003, 86.33699), (-36.25201, 46.11, 86.33699), (36.25201, 46.11, 86.33699), (36.25201, 50.085003, 86.33699), (36.25201, 50.085003, 13.833), (36.25201, 46.11, 86.33699), (36.25201, 46.11, 13.833)]
                texCoord2f[] primvars:st = [(0.21179199, 0.8405762), (0.21179199, 0.8701172), (0.16772461, 0.8405762), (0.16772461, 0.8701172), (0.55566406, 0.852417), (0.55566406, 0.822876), (0.5996094, 0.852417), (0.5996094, 0.822876), (0.83496094, 0.7907715), (0.8642578, 0.7907715), (0.83496094, 0.83483887), (0.8642578, 0.83483887), (0.69189453, 0.8607178), (0.69189453, 0.83117676), (0.7363281, 0.8607178), (0.7363281, 0.83117676), (0.75683594, 0.8572998), (0.75683594, 0.8277588), (0.80078125, 0.8572998), (0.80078125, 0.8277588), (0.5488281, 0.86486816), (0.50439453, 0.86486816), (0.5488281, 0.83532715), (0.50439453, 0.83532715), (0.80859375, 0.3696289), (0.80859375, 0.41503906), (0.8076172, 0.3696289), (0.8076172, 0.41503906), (0.9873047, 0.84350586), (0.9873047, 0.7982178), (0.98828125, 0.84350586), (0.98828125, 0.7982178), (0.9169922, 0.6147461), (0.9169922, 0.5695801), (0.9223633, 0.6147461), (0.9223633, 0.5695801), (0.6479492, 0.41503906), (0.6479492, 0.46044922), (0.6464844, 0.41503906), (0.6464844, 0.46044922), (0.17626953, 0.5559082), (0.13098145, 0.5559082), (0.17626953, 0.5546875), (0.13098145, 0.5546875), (0.98339844, 0.8586426), (0.98339844, 0.9024048), (0.9824219, 0.8586426), (0.9824219, 0.9024048), (0.9746094, 0.5739746), (0.97998047, 0.5739746), (0.9746094, 0.6191406), (0.97998047, 0.6191406), (0.5957031, 0.8638916), (0.5517578, 0.8638916), (0.5957031, 0.86279297), (0.5517578, 0.86279297), (0.97265625, 0.66748047), (0.96728516, 0.66748047), (0.97265625, 0.62231445), (0.96728516, 0.62231445), (0.45532227, 0.6359863), (0.4099121, 0.6359863), (0.45532227, 0.63500977), (0.4099121, 0.63500977), (0.4501953, 0.30859375), (0.4050293, 0.30859375), (0.4501953, 0.30322266), (0.4050293, 0.30322266), (0.15881348, 0.12988281), (0.113586426, 0.12988281), (0.15881348, 0.12890625), (0.113586426, 0.12890625), (0.9897461, 0.3154297), (0.9897461, 0.27001953), (0.99072266, 0.3154297), (0.99072266, 0.27001953), (0.06573486, 0.6296387), (0.06573486, 0.63500977), (0.020446777, 0.6296387), (0.020446777, 0.63500977), (0.9897461, 0.36376953), (0.9897461, 0.31835938), (0.99072266, 0.36376953), (0.99072266, 0.31835938), (0.3647461, 0.7441406), (0.31958008, 0.7441406), (0.3647461, 0.7429199), (0.31958008, 0.7429199), (0.41430664, 0.82177734), (0.36914062, 0.82177734), (0.41430664, 0.8206787), (0.36914062, 0.8206787), (0.8256836, 0.68725586), (0.8203125, 0.68725586), (0.8256836, 0.6435547), (0.8203125, 0.6435547), (0.20019531, 0.9772644), (0.17041016, 0.9772644), (0.20019531, 0.9705353), (0.17041016, 0.9705353), (0.07556152, 0.4506836), (0.045837402, 0.4506836), (0.07556152, 0.44384766), (0.045837402, 0.44384766), (0.23291016, 0.9772644), (0.203125, 0.9772644), (0.23291016, 0.9705353), (0.203125, 0.9705353), (0.9121094, 0.94085693), (0.8823242, 0.94085693), (0.9121094, 0.93414307), (0.8823242, 0.93414307), (0.5131836, 0.77197266), (0.5131836, 0.80163574), (0.50634766, 0.77197266), (0.50634766, 0.80163574), (0.23583984, 0.9705353), (0.265625, 0.9705353), (0.23583984, 0.9772644), (0.265625, 0.9772644), (0.84765625, 0.9628296), (0.8774414, 0.9628296), (0.84765625, 0.9695587), (0.8774414, 0.9695587), (0.2685547, 0.9705353), (0.29833984, 0.9705353), (0.2685547, 0.9772644), (0.29833984, 0.9772644), (0.001496315, 0.96383667), (0.031219482, 0.96383667), (0.001496315, 0.9705658), (0.031219482, 0.9705658), (0.034210205, 0.9640198), (0.06390381, 0.9640198), (0.034210205, 0.97076416), (0.06390381, 0.97076416), (0.30371094, 0.8742676), (0.30371094, 0.9039917), (0.296875, 0.8742676), (0.296875, 0.9039917), (0.09667969, 0.97076416), (0.06695557, 0.97076416), (0.09667969, 0.9640503), (0.06695557, 0.9640503), (0.09967041, 0.9640503), (0.12939453, 0.9640503), (0.09967041, 0.97076416), (0.12939453, 0.97076416), (0.4489746, 0.9748688), (0.41918945, 0.9748688), (0.4489746, 0.96813965), (0.41918945, 0.96813965), (0.9746094, 0.9064331), (0.9746094, 0.9361572), (0.96777344, 0.9064331), (0.96777344, 0.9361572), (0.4519043, 0.96694946), (0.48168945, 0.96694946), (0.4519043, 0.97366333), (0.48168945, 0.97366333), (0.84814453, 0.972641), (0.8774414, 0.972641), (0.84814453, 0.9793701), (0.8774414, 0.9793701), (0.5913086, 0.9663391), (0.62109375, 0.9663391), (0.5913086, 0.97306824), (0.62109375, 0.97306824), (0.62597656, 0.9633484), (0.6557617, 0.9633484), (0.62597656, 0.97006226), (0.6557617, 0.97006226), (0.68847656, 0.9701538), (0.6586914, 0.9701538), (0.68847656, 0.96343994), (0.6586914, 0.96343994), (0.0015048981, 0.9736328), (0.031219482, 0.9736328), (0.0015048981, 0.9803772), (0.031219482, 0.9803772), (0.7211914, 0.9702606), (0.69140625, 0.9702606), (0.7211914, 0.9635315), (0.69140625, 0.9635315), (0.48461914, 0.96762085), (0.51416016, 0.96762085), (0.48461914, 0.97436523), (0.51416016, 0.97436523), (0.7680664, 0.9682312), (0.79785156, 0.9682312), (0.7680664, 0.9749756), (0.79785156, 0.9749756), (0.9916992, 0.97639465), (0.9916992, 0.9467163), (0.99316406, 0.97639465), (0.99316406, 0.9467163), (0.9916992, 0.6381836), (0.9916992, 0.6086426), (0.99316406, 0.6381836), (0.99316406, 0.6086426), (0.031188965, 0.9929733), (0.0015029907, 0.9929733), (0.031188965, 0.99134827), (0.0015029907, 0.99134827), (0.9916992, 0.40185547), (0.9916992, 0.43115234), (0.9902344, 0.40185547), (0.9902344, 0.43115234), (0.99365234, 0.6413574), (0.99365234, 0.67089844), (0.9916992, 0.6413574), (0.9916992, 0.67089844), (0.44335938, 0.98747253), (0.41381836, 0.98747253), (0.44335938, 0.98583984), (0.41381836, 0.98583984), (0.47607422, 0.9879761), (0.44628906, 0.9879761), (0.47607422, 0.986351), (0.44628906, 0.986351), (0.99316406, 0.7307129), (0.99316406, 0.7602539), (0.9916992, 0.7307129), (0.9916992, 0.7602539), (0.9916992, 0.79296875), (0.9916992, 0.76330566), (0.99316406, 0.79296875), (0.99316406, 0.76330566), (0.9916992, 0.5073242), (0.9916992, 0.47753906), (0.99316406, 0.5073242), (0.99316406, 0.47753906), (0.83496094, 0.7858887), (0.8647461, 0.7858887), (0.83496094, 0.78759766), (0.8647461, 0.78759766), (0.4790039, 0.9863434), (0.50878906, 0.9863434), (0.4790039, 0.98796844), (0.50878906, 0.98796844), (0.5415039, 0.9879761), (0.51171875, 0.9879761), (0.5415039, 0.986351), (0.51171875, 0.986351), (0.22937012, 0.9869461), (0.2590332, 0.9869461), (0.22937012, 0.98857117), (0.2590332, 0.98857117), (0.99316406, 0.5102539), (0.99316406, 0.54003906), (0.9916992, 0.5102539), (0.9916992, 0.54003906), (0.9916992, 0.8256836), (0.9916992, 0.7960205), (0.99316406, 0.8256836), (0.99316406, 0.7960205), (0.9916992, 0.5727539), (0.9916992, 0.54296875), (0.99316406, 0.5727539), (0.99316406, 0.54296875), (0.9916992, 0.9109497), (0.9916992, 0.8812866), (0.99316406, 0.9109497), (0.99316406, 0.8812866), (0.053131104, 0.9882736), (0.0234375, 0.9882736), (0.053131104, 0.98664856), (0.0234375, 0.98664856), (0.06384277, 0.9929695), (0.034179688, 0.9929695), (0.06384277, 0.99134064), (0.034179688, 0.99134064), (0.19372559, 0.98857117), (0.16394043, 0.98857117), (0.19372559, 0.9869461), (0.16394043, 0.9869461), (0.19665527, 0.9869461), (0.22631836, 0.9869461), (0.19665527, 0.98857117), (0.22631836, 0.98857117), (0.99316406, 0.91400146), (0.99316406, 0.94366455), (0.9916992, 0.91400146), (0.9916992, 0.94366455), (0.99121094, 0.60546875), (0.99121094, 0.57592773), (0.99316406, 0.60546875), (0.99316406, 0.57592773)] (
                    interpolation = "vertex"
                texCoord2f[] primvars:st1 = [(0.20166016, 0.79833984), (0.20166016, 0.99193573), (0.00806427, 0.79833984), (0.00806427, 0.99193573), (0.00806427, 0.78234863), (0.00806427, 0.5888672), (0.20166016, 0.78234863), (0.20166016, 0.5888672), (0.63671875, 0.79833984), (0.8305664, 0.79833984), (0.63671875, 0.99193573), (0.8305664, 0.99193573), (0.21765137, 0.78234863), (0.21765137, 0.5888672), (0.4111328, 0.78234863), (0.4111328, 0.5888672), (0.21765137, 0.99193573), (0.21765137, 0.79833984), (0.4111328, 0.99193573), (0.4111328, 0.79833984), (0.62060547, 0.99193573), (0.4272461, 0.99193573), (0.62060547, 0.79833984), (0.4272461, 0.79833984), (0.11090088, 0.13623047), (0.11090088, 0.37939453), (0.10479736, 0.13623047), (0.10479736, 0.37939453), (0.97558594, 0.44384766), (0.97558594, 0.2006836), (0.9814453, 0.44384766), (0.9814453, 0.2006836), (0.00806427, 0.37939453), (0.00806427, 0.13623047), (0.037353516, 0.37939453), (0.037353516, 0.13623047), (0.9008789, 0.12011719), (0.9008789, 0.36328125), (0.89501953, 0.12011719), (0.89501953, 0.36328125), (0.4111328, 0.36328125), (0.4111328, 0.12011719), (0.41723633, 0.36328125), (0.41723633, 0.12011719), (0.14318848, 0.079589844), (0.14318848, 0.3149414), (0.13708496, 0.079589844), (0.13708496, 0.3149414), (0.79833984, 0.15234375), (0.8276367, 0.15234375), (0.79833984, 0.3955078), (0.8276367, 0.3955078), (0.7109375, 0.34716797), (0.47558594, 0.34716797), (0.7109375, 0.3408203), (0.47558594, 0.3408203), (0.87597656, 0.3955078), (0.8466797, 0.3955078), (0.87597656, 0.15234375), (0.8466797, 0.15234375), (0.44335938, 0.36328125), (0.44335938, 0.12011719), (0.4494629, 0.36328125), (0.4494629, 0.12011719), (0.7338867, 0.3955078), (0.49169922, 0.3955078), (0.7338867, 0.36572266), (0.49169922, 0.36572266), (0.9272461, 0.36328125), (0.9272461, 0.12011719), (0.93310547, 0.36328125), (0.93310547, 0.12011719), (0.97558594, 0.99193573), (0.97558594, 0.74902344), (0.9814453, 0.99193573), (0.9814453, 0.74902344), (0.7788086, 0.3955078), (0.75, 0.3955078), (0.7788086, 0.15234375), (0.75, 0.15234375), (0.97558594, 0.71777344), (0.97558594, 0.47509766), (0.9814453, 0.71777344), (0.9814453, 0.47509766), (0.38012695, 0.37939453), (0.13708496, 0.37939453), (0.38012695, 0.37304688), (0.13708496, 0.37304688), (0.3786621, 0.34716797), (0.13708496, 0.34716797), (0.3786621, 0.3408203), (0.13708496, 0.3408203), (0.08569336, 0.37939453), (0.056427002, 0.37939453), (0.08569336, 0.14404297), (0.056427002, 0.14404297), (0.8466797, 0.99193573), (0.8466797, 0.80249023), (0.88916016, 0.99193573), (0.88916016, 0.80249023), (0.4272461, 0.5727539), (0.4272461, 0.38330078), (0.4699707, 0.5727539), (0.4699707, 0.38330078), (0.40722656, 0.44384766), (0.21765137, 0.44384766), (0.40722656, 0.4013672), (0.21765137, 0.4013672), (0.9111328, 0.5727539), (0.9111328, 0.38330078), (0.9536133, 0.5727539), (0.9536133, 0.38330078), (0.95410156, 0.80249023), (0.95410156, 0.99193573), (0.9111328, 0.80249023), (0.9111328, 0.99193573), (0.49169922, 0.5461426), (0.68115234, 0.5461426), (0.49169922, 0.5888672), (0.68115234, 0.5888672), (0.7011719, 0.41748047), (0.8911133, 0.41748047), (0.7011719, 0.45996094), (0.8911133, 0.45996094), (0.7011719, 0.6105957), (0.8911133, 0.6105957), (0.7011719, 0.6533203), (0.8911133, 0.6533203), (0.49169922, 0.6750488), (0.68115234, 0.6750488), (0.49169922, 0.71777344), (0.68115234, 0.71777344), (0.7011719, 0.6750488), (0.8911133, 0.6750488), (0.7011719, 0.71777344), (0.8911133, 0.71777344), (0.9536133, 0.59277344), (0.9536133, 0.78234863), (0.9111328, 0.59277344), (0.9111328, 0.78234863), (0.8911133, 0.78234863), (0.7011719, 0.78234863), (0.8911133, 0.7397461), (0.7011719, 0.7397461), (0.00806427, 0.4013672), (0.19750977, 0.4013672), (0.00806427, 0.44384766), (0.19750977, 0.44384766), (0.8911133, 0.5888672), (0.7011719, 0.5888672), (0.8911133, 0.5461426), (0.7011719, 0.5461426), (0.47021484, 0.59277344), (0.47021484, 0.78234863), (0.4272461, 0.59277344), (0.4272461, 0.78234863), (0.49169922, 0.6105957), (0.68115234, 0.6105957), (0.49169922, 0.6533203), (0.68115234, 0.6533203), (0.21765137, 0.4658203), (0.40722656, 0.4658203), (0.21765137, 0.5083008), (0.40722656, 0.5083008), (0.49169922, 0.4819336), (0.68115234, 0.4819336), (0.49169922, 0.52441406), (0.68115234, 0.52441406), (0.00806427, 0.4658203), (0.19750977, 0.4658203), (0.00806427, 0.5083008), (0.19750977, 0.5083008), (0.8911133, 0.52441406), (0.7011719, 0.52441406), (0.8911133, 0.4819336), (0.7011719, 0.4819336), (0.00806427, 0.5300293), (0.19750977, 0.5300293), (0.00806427, 0.5727539), (0.19750977, 0.5727539), (0.68115234, 0.78234863), (0.49169922, 0.78234863), (0.68115234, 0.73950195), (0.49169922, 0.73950195), (0.21765137, 0.5300293), (0.40722656, 0.5300293), (0.21765137, 0.5727539), (0.40722656, 0.5727539), (0.49169922, 0.41748047), (0.68115234, 0.41748047), (0.49169922, 0.45996094), (0.68115234, 0.45996094), (0.63671875, 0.080078125), (0.7963867, 0.080078125), (0.63671875, 0.08886719), (0.7963867, 0.08886719), (0.47558594, 0.25), (0.47558594, 0.09082031), (0.484375, 0.25), (0.484375, 0.09082031), (0.7963867, 0.12109375), (0.63671875, 0.12109375), (0.7963867, 0.11230469), (0.63671875, 0.11230469), (0.51660156, 0.09082031), (0.51660156, 0.25), (0.5078125, 0.09082031), (0.5078125, 0.25), (0.32861328, 0.10498047), (0.16931152, 0.10498047), (0.32861328, 0.096191406), (0.16931152, 0.096191406), (0.5722656, 0.25), (0.5722656, 0.09082031), (0.5810547, 0.25), (0.5810547, 0.09082031), (0.5058594, 0.072753906), (0.3466797, 0.072753906), (0.5058594, 0.063964844), (0.3466797, 0.063964844), (0.9682617, 0.010253906), (0.9682617, 0.1694336), (0.95947266, 0.010253906), (0.95947266, 0.1694336), (0.37890625, 0.3149414), (0.37890625, 0.15527344), (0.3876953, 0.3149414), (0.3876953, 0.15527344), (0.16931152, 0.28271484), (0.16931152, 0.123046875), (0.17797852, 0.28271484), (0.17797852, 0.123046875), (0.16931152, 0.30615234), (0.32861328, 0.30615234), (0.16931152, 0.3149414), (0.32861328, 0.3149414), (0.47558594, 0.30615234), (0.6347656, 0.30615234), (0.47558594, 0.3149414), (0.6347656, 0.3149414), (0.29833984, 0.28271484), (0.29833984, 0.123046875), (0.30688477, 0.28271484), (0.30688477, 0.123046875), (0.21032715, 0.123046875), (0.21032715, 0.28271484), (0.20153809, 0.123046875), (0.20153809, 0.28271484), (0.2746582, 0.123046875), (0.2746582, 0.28271484), (0.26611328, 0.123046875), (0.26611328, 0.28271484), (0.23376465, 0.28271484), (0.23376465, 0.123046875), (0.24255371, 0.28271484), (0.24255371, 0.123046875), (0.3466797, 0.3149414), (0.3466797, 0.15527344), (0.35546875, 0.3149414), (0.35546875, 0.15527344), (0.71728516, 0.3149414), (0.71728516, 0.15527344), (0.7260742, 0.3149414), (0.7260742, 0.15527344), (0.6850586, 0.3149414), (0.6850586, 0.15527344), (0.69384766, 0.3149414), (0.69384766, 0.15527344), (0.65283203, 0.3149414), (0.65283203, 0.15527344), (0.6616211, 0.3149414), (0.6616211, 0.15527344), (0.6347656, 0.28271484), (0.47558594, 0.28271484), (0.6347656, 0.27392578), (0.47558594, 0.27392578), (0.61328125, 0.09082031), (0.61328125, 0.25048828), (0.6044922, 0.09082031), (0.6044922, 0.25048828), (0.5488281, 0.09082031), (0.5488281, 0.25), (0.54003906, 0.09082031), (0.54003906, 0.25), (0.16931152, 0.063964844), (0.32861328, 0.063964844), (0.16931152, 0.072753906), (0.32861328, 0.072753906)] (
                custom string unrealMaterial = "/Game/Environment_Set/MedievalKingdom/Content/Materials/Materials_Instances/Props/MI_Props_1.MI_Props_1"
        "LOD1" {
            def Mesh "LOD1"
                int[] faceVertexCounts = [3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3]
                int[] faceVertexIndices = [0, 1, 2, 1, 3, 2, 4, 5, 6, 5, 7, 6, 8, 9, 10, 9, 11, 10, 12, 13, 14, 13, 15, 14, 16, 17, 18, 17, 19, 18, 20, 21, 22, 21, 23, 22, 24, 25, 26, 25, 27, 26, 28, 29, 30, 29, 31, 30, 32, 33, 34, 33, 35, 34, 36, 37, 38, 37, 39, 38, 40, 41, 42, 41, 43, 42, 44, 45, 46, 45, 47, 46, 48, 49, 50, 49, 51, 50, 52, 53, 54, 53, 55, 54, 56, 57, 58, 57, 59, 58, 60, 61, 62, 61, 63, 62, 64, 65, 66, 65, 67, 66, 68, 69, 70, 69, 71, 70, 72, 73, 74, 73, 75, 74, 76, 77, 78, 77, 79, 78, 80, 81, 82, 81, 83, 82, 84, 85, 86, 85, 87, 86, 88, 89, 90, 89, 91, 90, 92, 93, 94, 93, 95, 94, 96, 97, 98, 97, 99, 98, 100, 101, 102, 101, 103, 102, 104, 105, 106, 105, 107, 106, 108, 109, 110, 109, 111, 110, 112, 113, 114, 113, 115, 114, 116, 117, 118, 117, 119, 118, 120, 121, 122, 121, 123, 122, 124, 125, 126, 125, 127, 126, 128, 129, 130, 129, 131, 130, 132, 133, 134, 133, 135, 134, 136, 137, 138, 137, 139, 138, 140, 141, 142, 141, 143, 142]
                normal3f[] normals = [(0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (0, -0, 1), (0, -0, 1), (0, -0, 1), (0, -0, 1), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -0, 1), (0, -0, 1), (0, -0, 1), (0, -0, 1), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-0.007874016, 0.007874016, 1), (-0.007874016, -0.007874016, 1), (-0.007874016, 0.007874016, 1), (-0.007874016, -0.007874016, 1), (-0.007874016, -0.007874016, 1), (0.007874016, -0.007874016, 1), (-0.007874016, -0.007874016, 1), (0.007874016, -0.007874016, 1), (0.007874016, -0.007874016, 1), (0.007874016, 0.007874016, 1), (0.007874016, -0.007874016, 1), (0.007874016, 0.007874016, 1), (0.007874016, 0.007874016, 1), (-0.007874016, 0.007874016, 1), (0.007874016, 0.007874016, 1), (-0.007874016, 0.007874016, 1), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0)]
                point3f[] points = [(-44.046192, 46.11, 6.038819), (-44.046192, 46.11, 94.13118), (44.046192, 46.11, 6.038819), (44.046192, 46.11, 94.13118), (-46.10997, -44.04618, 6.038819), (-46.10997, -44.04618, 94.13118), (-46.10997, 44.04618, 6.038819), (-46.10997, 44.04618, 94.13118), (-44.046192, -44.04618, 96.195), (44.046192, -44.04618, 96.195), (-44.046192, 44.04618, 96.195), (44.046192, 44.04618, 96.195), (46.10997, -44.04618, 94.13118), (46.10997, -44.04618, 6.038819), (46.10997, 44.04618, 94.13118), (46.10997, 44.04618, 6.038819), (44.046192, -44.04618, 3.9750009), (-44.046192, -44.04618, 3.9750009), (44.046192, 44.04618, 3.9750009), (-44.046192, 44.04618, 3.9750009), (-44.046192, -46.11, 6.038819), (44.046192, -46.11, 6.038819), (-44.046192, -46.11, 94.13118), (44.046192, -46.11, 94.13118), (-44.501858, 33.715504, 98.3749), (33.841793, -43.946842, 98.88735), (-33.837437, 43.96022, 98.88201), (44.501827, -33.715473, 98.3749), (-48.289867, -33.715446, 5.583205), (-48.79697, -43.96021, 16.247583), (-48.802315, 43.94689, 83.92681), (-48.28987, 33.715485, 94.586815), (-44.501865, -48.28991, 16.369482), (-33.837456, -48.79701, 6.1247544), (33.841785, -48.802357, 94.031815), (44.5018, -48.2899, 83.80043), (-44.409637, -32.8688, 1.7694261), (33.862564, 43.918755, 1.2786586), (-33.872448, -43.94939, 1.285944), (44.52364, 33.699608, 1.7950932), (48.289875, 33.715523, 5.5831413), (48.79697, 43.960243, 16.247562), (48.802315, -43.946823, 83.92676), (48.289867, -33.715446, 94.586784), (43.240303, 48.28991, 17.631054), (32.58021, 48.802345, 7.3996), (-32.57581, 48.797012, 92.7837), (-43.24027, 48.289906, 82.5389), (50, 50, -0.000008146034), (-50, 50, -0.000008146034), (35.031506, 49.47014, 15.047622), (-35.111576, 49.70754, 14.930813), (-50, 50, -0.000008146034), (-50, 50.00002, 99.99999), (-35.111576, 49.70754, 14.930813), (-35.025066, 49.46271, 85.12078), (-50, 50.00002, 99.99999), (50, 50.00002, 99.99999), (-35.025066, 49.46271, 85.12078), (35.1078, 49.705727, 85.23915), (50, 50.00002, 99.99999), (50, 50, -0.000008146034), (35.1078, 49.705727, 85.23915), (35.031506, 49.47014, 15.047622), (-50, 50, -0.000008146034), (-50, -50, 0.000008146034), (-49.470108, 35.031487, 15.047669), (-49.707516, -35.111534, 14.930832), (-50, -50, 0.000008146034), (-50, -49.999985, 100.000015), (-49.707516, -35.111534, 14.930832), (-49.462692, -35.025074, 85.12075), (-50, -49.999985, 100.000015), (-50, 50.00002, 99.99999), (-49.462692, -35.025074, 85.12075), (-49.705704, 35.10775, 85.23915), (-50, 50.00002, 99.99999), (-50, 50, -0.000008146034), (-49.705704, 35.10775, 85.23915), (-49.470108, 35.031487, 15.047669), (-50, 50.00002, 99.99999), (-50, -49.999985, 100.000015), (-35.12193, 35.156715, 99.80118), (-35.025185, -35.041897, 99.5595), (-50, -49.999985, 100.000015), (50, -49.999985, 100.000015), (-35.025185, -35.041897, 99.5595), (35.121906, -35.1567, 99.80117), (50, -49.999985, 100.000015), (50, 50.00002, 99.99999), (35.121906, -35.1567, 99.80117), (35.02517, 35.041924, 99.55951), (50, 50.00002, 99.99999), (-50, 50.00002, 99.99999), (35.02517, 35.041924, 99.55951), (-35.12193, 35.156715, 99.80118), (50, 50.00002, 99.99999), (50, -49.999985, 100.000015), (49.46269, 35.025063, 85.12075), (49.705704, -35.107765, 85.23913), (50, -49.999985, 100.000015), (50, -50, 0.000008146034), (49.705704, -35.107765, 85.23913), (49.47011, -35.03147, 15.047652), (50, -50, 0.000008146034), (50, 50, -0.000008146034), (49.47011, -35.03147, 15.047652), (49.707516, 35.111538, 14.930831), (50, 50, -0.000008146034), (50, 50.00002, 99.99999), (49.707516, 35.111538, 14.930831), (49.46269, 35.025063, 85.12075), (50, 50, -0.000008146034), (50, -50, 0.000008146034), (35.09783, 35.15187, 0.3879215), (35.031536, -35.03151, 0.62655985), (50, -50, 0.000008146034), (-50, -50, 0.000008146034), (35.031536, -35.03151, 0.62655985), (-35.09781, -35.15187, 0.38792452), (-50, -50, 0.000008146034), (-50, 50, -0.000008146034), (-35.09781, -35.15187, 0.38792452), (-35.031506, 35.031525, 0.6265656), (-50, 50, -0.000008146034), (50, 50, -0.000008146034), (-35.031506, 35.031525, 0.6265656), (35.09783, 35.15187, 0.3879215), (-50, -49.999985, 100.000015), (-50, -50, 0.000008146034), (-35.107773, -49.705723, 85.23915), (-35.03149, -49.47013, 15.047633), (-50, -50, 0.000008146034), (50, -50, 0.000008146034), (-35.03149, -49.47013, 15.047633), (35.11156, -49.707535, 14.93083), (50, -50, 0.000008146034), (50, -49.999985, 100.000015), (35.11156, -49.707535, 14.93083), (35.02507, -49.46271, 85.12077), (50, -49.999985, 100.000015), (-50, -49.999985, 100.000015), (35.02507, -49.46271, 85.12077), (-35.107773, -49.705723, 85.23915)]
                texCoord2f[] primvars:st = [(0.21179199, 0.8405762), (0.21179199, 0.8701172), (0.16772461, 0.8405762), (0.16772461, 0.8701172), (0.55566406, 0.852417), (0.55566406, 0.822876), (0.5996094, 0.852417), (0.5996094, 0.822876), (0.83496094, 0.7907715), (0.8642578, 0.7907715), (0.83496094, 0.83483887), (0.8642578, 0.83483887), (0.69189453, 0.8607178), (0.69189453, 0.83117676), (0.7363281, 0.8607178), (0.7363281, 0.83117676), (0.75683594, 0.8572998), (0.75683594, 0.8277588), (0.80078125, 0.8572998), (0.80078125, 0.8277588), (0.5488281, 0.86486816), (0.50439453, 0.86486816), (0.5488281, 0.83532715), (0.50439453, 0.83532715), (0.9165039, 0.6147461), (0.9165039, 0.5698242), (0.9223633, 0.6147461), (0.9223633, 0.5695801), (0.9741211, 0.57421875), (0.97998047, 0.57421875), (0.9741211, 0.6191406), (0.97998047, 0.6191406), (0.97265625, 0.6677246), (0.9667969, 0.66748047), (0.97265625, 0.6225586), (0.9667969, 0.6225586), (0.4501953, 0.30908203), (0.4050293, 0.30908203), (0.44995117, 0.30322266), (0.4050293, 0.30322266), (0.06573486, 0.62939453), (0.06561279, 0.6352539), (0.020568848, 0.6296387), (0.020446777, 0.63549805), (0.8256836, 0.6875), (0.8198242, 0.68725586), (0.8256836, 0.6437988), (0.8198242, 0.6435547), (0.20019531, 0.9772644), (0.17041016, 0.9772644), (0.19970703, 0.96995544), (0.17041016, 0.9700165), (0.07556152, 0.4506836), (0.045837402, 0.4506836), (0.07513428, 0.44335938), (0.045837402, 0.44335938), (0.23291016, 0.9772644), (0.203125, 0.9772644), (0.23242188, 0.9699402), (0.203125, 0.9700012), (0.9121094, 0.94085693), (0.8823242, 0.94085693), (0.9116211, 0.93359375), (0.88183594, 0.93359375), (0.5131836, 0.77197266), (0.5131836, 0.80163574), (0.5053711, 0.77246094), (0.5053711, 0.80163574), (0.23583984, 0.9705353), (0.265625, 0.9705353), (0.23620605, 0.977829), (0.26538086, 0.97787476), (0.84765625, 0.9628296), (0.8774414, 0.9628296), (0.84765625, 0.97016907), (0.8769531, 0.97010803), (0.2685547, 0.9705353), (0.29833984, 0.9705353), (0.26879883, 0.977829), (0.29833984, 0.97787476), (0.001496315, 0.96383667), (0.031219482, 0.96383667), (0.0018959045, 0.9711304), (0.031219482, 0.97117615), (0.034210205, 0.9640198), (0.06390381, 0.9640198), (0.034606934, 0.97135925), (0.06384277, 0.9712982), (0.30371094, 0.8742676), (0.30371094, 0.9039917), (0.29614258, 0.87475586), (0.29614258, 0.90405273), (0.09667969, 0.97076416), (0.06695557, 0.97076416), (0.09625244, 0.96347046), (0.06695557, 0.9635315), (0.09967041, 0.9640503), (0.12939453, 0.9640503), (0.10003662, 0.9713745), (0.12927246, 0.9713135), (0.4489746, 0.9748688), (0.41918945, 0.9748688), (0.44848633, 0.96759033), (0.4189453, 0.9675598), (0.9746094, 0.9064331), (0.9746094, 0.9361572), (0.9667969, 0.90686035), (0.9667969, 0.9361572), (0.4519043, 0.96694946), (0.48168945, 0.96694946), (0.45214844, 0.9742279), (0.4814453, 0.9742737), (0.84814453, 0.972641), (0.8774414, 0.972641), (0.84814453, 0.97994995), (0.8774414, 0.97998047), (0.5913086, 0.9663391), (0.62109375, 0.9663391), (0.5913086, 0.9736786), (0.62060547, 0.97361755), (0.62597656, 0.9633484), (0.6557617, 0.9633484), (0.62597656, 0.9706421), (0.6557617, 0.9706726), (0.68847656, 0.9701538), (0.6586914, 0.9701538), (0.6879883, 0.9628601), (0.6586914, 0.96292114), (0.0015048981, 0.9736328), (0.031219482, 0.9736328), (0.0019083023, 0.9809418), (0.031219482, 0.98098755), (0.7211914, 0.9702606), (0.69140625, 0.9702606), (0.7207031, 0.96295166), (0.69140625, 0.9630127), (0.48461914, 0.96762085), (0.51416016, 0.96762085), (0.48486328, 0.9749298), (0.5136719, 0.9749756), (0.7680664, 0.9682312), (0.79785156, 0.9682312), (0.7680664, 0.97558594), (0.7973633, 0.9755249)] (
                texCoord2f[] primvars:st1 = [(0.20166016, 0.79833984), (0.20166016, 0.99193573), (0.00806427, 0.79833984), (0.00806427, 0.99193573), (0.00806427, 0.78234863), (0.00806427, 0.5888672), (0.20166016, 0.78234863), (0.20166016, 0.5888672), (0.63671875, 0.79833984), (0.8305664, 0.79833984), (0.63671875, 0.99193573), (0.8305664, 0.99193573), (0.21765137, 0.78234863), (0.21765137, 0.5888672), (0.4111328, 0.78234863), (0.4111328, 0.5888672), (0.21765137, 0.99193573), (0.21765137, 0.79833984), (0.4111328, 0.99193573), (0.4111328, 0.79833984), (0.62060547, 0.99193573), (0.4272461, 0.99193573), (0.62060547, 0.79833984), (0.4272461, 0.79833984), (0.005947113, 0.37939453), (0.007007599, 0.13671875), (0.03842163, 0.37841797), (0.03945923, 0.13623047), (0.79589844, 0.15234375), (0.8286133, 0.15283203), (0.796875, 0.39453125), (0.82958984, 0.3955078), (0.8779297, 0.3955078), (0.84521484, 0.39453125), (0.8769531, 0.15283203), (0.8442383, 0.15234375), (0.7338867, 0.39746094), (0.49243164, 0.39648438), (0.73339844, 0.3642578), (0.49169922, 0.36328125), (0.78125, 0.3955078), (0.74853516, 0.39453125), (0.78027344, 0.15283203), (0.7475586, 0.15234375), (0.08782959, 0.37939453), (0.055389404, 0.37841797), (0.08679199, 0.14453125), (0.05432129, 0.14404297), (0.8466797, 0.99193573), (0.8466797, 0.80249023), (0.8930664, 0.9892578), (0.8925781, 0.8026123), (0.4272461, 0.5727539), (0.4272461, 0.38330078), (0.4736328, 0.57006836), (0.47387695, 0.38330078), (0.40722656, 0.44384766), (0.21765137, 0.44384766), (0.40454102, 0.39746094), (0.21777344, 0.39794922), (0.9111328, 0.5727539), (0.9111328, 0.38330078), (0.95751953, 0.57006836), (0.95751953, 0.38330078), (0.95410156, 0.80249023), (0.95410156, 0.99193573), (0.90722656, 0.8051758), (0.90771484, 0.99178314), (0.49169922, 0.5461426), (0.68115234, 0.5461426), (0.49438477, 0.59228516), (0.68115234, 0.5925293), (0.7011719, 0.41748047), (0.8911133, 0.41748047), (0.70410156, 0.4638672), (0.890625, 0.4633789), (0.7011719, 0.6105957), (0.8911133, 0.6105957), (0.70410156, 0.6569824), (0.8911133, 0.65722656), (0.49169922, 0.6750488), (0.68115234, 0.6750488), (0.49438477, 0.72143555), (0.68115234, 0.7216797), (0.7011719, 0.6750488), (0.8911133, 0.6750488), (0.70410156, 0.7216797), (0.890625, 0.7211914), (0.9536133, 0.59277344), (0.9536133, 0.78234863), (0.90771484, 0.595459), (0.90722656, 0.78234863), (0.8911133, 0.78234863), (0.7011719, 0.78234863), (0.8881836, 0.73583984), (0.70166016, 0.7363281), (0.00806427, 0.4013672), (0.19750977, 0.4013672), (0.010757446, 0.4477539), (0.1973877, 0.44726562), (0.8911133, 0.5888672), (0.7011719, 0.5888672), (0.8881836, 0.54248047), (0.7011719, 0.5422363), (0.47021484, 0.59277344), (0.47021484, 0.78234863), (0.42358398, 0.595459), (0.42382812, 0.7821045), (0.49169922, 0.6105957), (0.68115234, 0.6105957), (0.49438477, 0.6569824), (0.68115234, 0.65722656), (0.21765137, 0.4658203), (0.40722656, 0.4658203), (0.22021484, 0.51171875), (0.40722656, 0.5119629), (0.49169922, 0.4819336), (0.68115234, 0.4819336), (0.49438477, 0.5280762), (0.68115234, 0.52783203), (0.00806427, 0.4658203), (0.19750977, 0.4658203), (0.010627747, 0.51171875), (0.19750977, 0.5119629), (0.8911133, 0.52441406), (0.7011719, 0.52441406), (0.8881836, 0.47802734), (0.70166016, 0.47851562), (0.00806427, 0.5300293), (0.19750977, 0.5300293), (0.010635376, 0.5761719), (0.19763184, 0.576416), (0.68115234, 0.78234863), (0.49169922, 0.78234863), (0.67871094, 0.73583984), (0.49194336, 0.736084), (0.21765137, 0.5300293), (0.40722656, 0.5300293), (0.22021484, 0.5761719), (0.40722656, 0.576416), (0.49169922, 0.41748047), (0.68115234, 0.41748047), (0.4946289, 0.4638672), (0.68115234, 0.4633789)] (
        "LOD2" {
            def Mesh "LOD2"
                int[] faceVertexCounts = [3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3]
                int[] faceVertexIndices = [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 73, 75, 74, 76, 77, 78, 77, 79, 78, 80, 81, 82, 81, 83, 82, 84, 85, 86, 85, 87, 86, 88, 89, 90, 89, 91, 90, 92, 93, 94, 93, 95, 94]
                normal3f[] normals = [(0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-0.007874016, -0.007874016, 1), (-0.007874016, -0.007874016, 1), (-0.007874016, 0.007874016, 1), (-0.007874016, -0.007874016, 1), (0.007874016, -0.007874016, 1), (-0.007874016, -0.007874016, 1), (0.007874016, 0.007874016, 1), (0.007874016, 0.007874016, 1), (0.007874016, -0.007874016, 1), (0.007874016, 0.007874016, 1), (-0.007874016, 0.007874016, 1), (0.007874016, 0.007874016, 1), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (0, -0, 1), (0, -0, 1), (0, -0, 1), (0, -0, 1), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0)]
                point3f[] points = [(50.058132, 46.418312, 0.59731746), (-47.37321, 51.73583, 2.4858828), (35.031506, 49.47014, 15.047622), (-49.26469, 46.321186, 100.11689), (-35.025066, 49.46271, 85.12078), (-47.37321, 51.73583, 2.4858828), (-49.26469, 46.321186, 100.11689), (47.8633, 52.04546, 98.03368), (-35.025066, 49.46271, 85.12078), (50.058132, 46.418312, 0.59731746), (35.031506, 49.47014, 15.047622), (47.8633, 52.04546, 98.03368), (-47.37321, 51.73583, 2.4858828), (-50.058125, -46.41831, 0.597315), (-49.470108, 35.031487, 15.047669), (-47.86329, -52.04544, 98.0337), (-49.462692, -35.025074, 85.12075), (-50.058125, -46.41831, 0.597315), (-47.86329, -52.04544, 98.0337), (-49.26469, 46.321186, 100.11689), (-49.462692, -35.025074, 85.12075), (-47.37321, 51.73583, 2.4858828), (-49.470108, 35.031487, 15.047669), (-49.26469, 46.321186, 100.11689), (-47.86329, -52.04544, 98.0337), (-35.025185, -35.041897, 99.5595), (-49.26469, 46.321186, 100.11689), (-47.86329, -52.04544, 98.0337), (49.26466, -46.321167, 100.116905), (-35.025185, -35.041897, 99.5595), (47.8633, 52.04546, 98.03368), (35.02517, 35.041924, 99.55951), (49.26466, -46.321167, 100.116905), (47.8633, 52.04546, 98.03368), (-49.26469, 46.321186, 100.11689), (35.02517, 35.041924, 99.55951), (47.8633, 52.04546, 98.03368), (49.26466, -46.321167, 100.116905), (49.46269, 35.025063, 85.12075), (47.37321, -51.73582, 2.4858952), (49.47011, -35.03147, 15.047652), (49.26466, -46.321167, 100.116905), (47.37321, -51.73582, 2.4858952), (50.058132, 46.418312, 0.59731746), (49.47011, -35.03147, 15.047652), (47.8633, 52.04546, 98.03368), (49.46269, 35.025063, 85.12075), (50.058132, 46.418312, 0.59731746), (47.37321, -51.73582, 2.4858952), (35.031536, -35.03151, 0.62655985), (50.058132, 46.418312, 0.59731746), (47.37321, -51.73582, 2.4858952), (-50.058125, -46.41831, 0.597315), (35.031536, -35.03151, 0.62655985), (-47.37321, 51.73583, 2.4858828), (-35.031506, 35.031525, 0.6265656), (-50.058125, -46.41831, 0.597315), (-47.37321, 51.73583, 2.4858828), (50.058132, 46.418312, 0.59731746), (-35.031506, 35.031525, 0.6265656), (-50.058125, -46.41831, 0.597315), (-35.03149, -49.47013, 15.047633), (-47.86329, -52.04544, 98.0337), (-50.058125, -46.41831, 0.597315), (47.37321, -51.73582, 2.4858952), (-35.03149, -49.47013, 15.047633), (49.26466, -46.321167, 100.116905), (35.02507, -49.46271, 85.12077), (47.37321, -51.73582, 2.4858952), (49.26466, -46.321167, 100.116905), (-47.86329, -52.04544, 98.0337), (35.02507, -49.46271, 85.12077), (-44.046192, 46.11, 6.038819), (-44.046192, 46.11, 94.13118), (44.046192, 46.11, 6.038819), (44.046192, 46.11, 94.13118), (-46.10997, -44.04618, 6.038819), (-46.10997, -44.04618, 94.13118), (-46.10997, 44.04618, 6.038819), (-46.10997, 44.04618, 94.13118), (-44.046192, -44.04618, 96.195), (44.046192, -44.04618, 96.195), (-44.046192, 44.04618, 96.195), (44.046192, 44.04618, 96.195), (46.10997, -44.04618, 94.13118), (46.10997, -44.04618, 6.038819), (46.10997, 44.04618, 94.13118), (46.10997, 44.04618, 6.038819), (44.046192, -44.04618, 3.9750009), (-44.046192, -44.04618, 3.9750009), (44.046192, 44.04618, 3.9750009), (-44.046192, 44.04618, 3.9750009), (-44.046192, -46.11, 6.038819), (44.046192, -46.11, 6.038819), (-44.046192, -46.11, 94.13118), (44.046192, -46.11, 94.13118)]
                texCoord2f[] primvars:st = [(0.20031738, 0.977005), (0.17102051, 0.9760437), (0.19970703, 0.96995544), (0.044952393, 0.4506836), (0.045837402, 0.44335938), (0.078125, 0.44970703), (0.23254395, 0.9773407), (0.20361328, 0.9762726), (0.23242188, 0.9699402), (0.8828125, 0.94091797), (0.88183594, 0.93359375), (0.9145508, 0.9397888), (0.51171875, 0.770874), (0.5126953, 0.80078125), (0.5053711, 0.77246094), (0.26489258, 0.96951294), (0.26538086, 0.97787476), (0.2322998, 0.97239685), (0.8461914, 0.9638672), (0.8769531, 0.962677), (0.84765625, 0.97016907), (0.296875, 0.96977234), (0.29833984, 0.97787476), (0.265625, 0.9721832), (0.031951904, 0.96484375), (0.031219482, 0.97117615), (-0.00024986267, 0.96429443), (0.03540039, 0.9630432), (0.06384277, 0.9659424), (0.034606934, 0.97135925), (0.30249023, 0.90478516), (0.29614258, 0.90405273), (0.30322266, 0.8725586), (0.095458984, 0.971756), (0.06695557, 0.9688568), (0.09625244, 0.96347046), (0.09844971, 0.9650879), (0.12890625, 0.9638977), (0.10003662, 0.9713745), (0.42041016, 0.975647), (0.4189453, 0.9675598), (0.45166016, 0.9732361), (0.97314453, 0.9053345), (0.9741211, 0.9352417), (0.9667969, 0.90686035), (0.48095703, 0.9659424), (0.4814453, 0.9742737), (0.4482422, 0.9687958), (0.87890625, 0.9740143), (0.8774414, 0.97998047), (0.84521484, 0.97250366), (0.59228516, 0.9655762), (0.62060547, 0.96795654), (0.5913086, 0.9736786), (0.65722656, 0.9647217), (0.6557617, 0.9706726), (0.6230469, 0.9632263), (0.6870117, 0.970932), (0.6586914, 0.9685669), (0.6879883, 0.9628601), (0.030334473, 0.9736023), (0.031219482, 0.98098755), (-0.0010910034, 0.97473145), (0.7211914, 0.9700012), (0.69189453, 0.9690399), (0.7207031, 0.96295166), (0.51464844, 0.96795654), (0.5136719, 0.9749756), (0.4819336, 0.96894836), (0.7680664, 0.96817017), (0.796875, 0.9692383), (0.7680664, 0.97558594), (0.21179199, 0.8405762), (0.21179199, 0.8701172), (0.16772461, 0.8405762), (0.16772461, 0.8701172), (0.55566406, 0.852417), (0.55566406, 0.822876), (0.5996094, 0.852417), (0.5996094, 0.822876), (0.83496094, 0.7907715), (0.8642578, 0.7907715), (0.83496094, 0.83483887), (0.8642578, 0.83483887), (0.69189453, 0.8607178), (0.69189453, 0.83117676), (0.7363281, 0.8607178), (0.7363281, 0.83117676), (0.75683594, 0.8572998), (0.75683594, 0.8277588), (0.80078125, 0.8572998), (0.80078125, 0.8277588), (0.5488281, 0.86486816), (0.50439453, 0.86486816), (0.5488281, 0.83532715), (0.50439453, 0.83532715)] (
                texCoord2f[] primvars:st1 = [(0.84814453, 0.99334335), (0.8544922, 0.80688477), (0.8930664, 0.9892578), (0.42944336, 0.3774414), (0.47387695, 0.38330078), (0.43579102, 0.58935547), (0.40551758, 0.44433594), (0.22106934, 0.4375), (0.40454102, 0.39746094), (0.91064453, 0.38867188), (0.95751953, 0.38330078), (0.91796875, 0.58935547), (0.94628906, 0.795166), (0.9511719, 0.9860306), (0.90722656, 0.8051758), (0.6767578, 0.5395508), (0.68115234, 0.5925293), (0.46948242, 0.5578613), (0.69384766, 0.42382812), (0.8881836, 0.4165039), (0.70410156, 0.4638672), (0.8823242, 0.6057129), (0.8911133, 0.65722656), (0.68359375, 0.62109375), (0.68603516, 0.6813965), (0.68115234, 0.7216797), (0.4807129, 0.6779785), (0.7089844, 0.6689453), (0.890625, 0.68725586), (0.70410156, 0.7216797), (0.9472656, 0.7869873), (0.90722656, 0.78234863), (0.9511719, 0.5817871), (0.8833008, 0.7885742), (0.70166016, 0.7701416), (0.8881836, 0.73583984), (0.00033545494, 0.40771484), (0.19482422, 0.40039062), (0.010757446, 0.4477539), (0.70996094, 0.59375), (0.7011719, 0.5422363), (0.9086914, 0.57836914), (0.46240234, 0.5854492), (0.4675293, 0.7763672), (0.42358398, 0.595459), (0.6767578, 0.6040039), (0.68115234, 0.65722656), (0.46948242, 0.62231445), (0.4169922, 0.4741211), (0.40722656, 0.5119629), (0.19995117, 0.46484375), (0.49951172, 0.47705078), (0.6791992, 0.49169922), (0.49438477, 0.5280762), (0.20739746, 0.4741211), (0.19750977, 0.5119629), (-0.0096588135, 0.46484375), (0.8833008, 0.5292969), (0.703125, 0.51416016), (0.8881836, 0.47802734), (0.19189453, 0.52978516), (0.19763184, 0.576416), (-0.0084991455, 0.53686523), (0.6826172, 0.7805176), (0.4963379, 0.77453613), (0.67871094, 0.73583984), (0.4128418, 0.5319824), (0.40722656, 0.576416), (0.2010498, 0.5383301), (0.49365234, 0.4169922), (0.6777344, 0.42382812), (0.4946289, 0.4638672), (0.20166016, 0.79833984), (0.20166016, 0.99193573), (0.00806427, 0.79833984), (0.00806427, 0.99193573), (0.00806427, 0.78234863), (0.00806427, 0.5888672), (0.20166016, 0.78234863), (0.20166016, 0.5888672), (0.63671875, 0.79833984), (0.8305664, 0.79833984), (0.63671875, 0.99193573), (0.8305664, 0.99193573), (0.21765137, 0.78234863), (0.21765137, 0.5888672), (0.4111328, 0.78234863), (0.4111328, 0.5888672), (0.21765137, 0.99193573), (0.21765137, 0.79833984), (0.4111328, 0.99193573), (0.4111328, 0.79833984), (0.62060547, 0.99193573), (0.4272461, 0.99193573), (0.62060547, 0.79833984), (0.4272461, 0.79833984)] (
        "LOD3" {
            def Mesh "LOD3"
                int[] faceVertexCounts = [3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3]
                int[] faceVertexIndices = [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 19, 21, 20, 22, 23, 24, 23, 25, 24, 26, 27, 28, 27, 29, 28, 30, 31, 32, 31, 33, 32, 34, 35, 36, 35, 37, 36, 38, 39, 40, 39, 41, 40]
                normal3f[] normals = [(0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0.007874016, 0.007874016, 1), (0.007874016, 0.007874016, 1), (0.007874016, -0.007874016, 1), (0.007874016, 0.007874016, 1), (-0.007874016, 0.007874016, 1), (0.007874016, 0.007874016, 1), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (0, 1, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (-1, -0, 0), (0, -0, 1), (0, -0, 1), (0, -0, 1), (0, -0, 1), (1, -0, 0), (1, -0, 0), (1, -0, 0), (1, -0, 0), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -0, -1), (0, -1, 0), (0, -1, 0), (0, -1, 0), (0, -1, 0)]
                point3f[] points = [(-49.26469, 46.321186, 100.11689), (-35.025066, 49.46271, 85.12078), (-50.730923, 46.649563, 3.28478), (-49.26469, 46.321186, 100.11689), (47.8633, 52.04546, 98.03368), (-35.025066, 49.46271, 85.12078), (47.8633, 52.04546, 98.03368), (35.02517, 35.041924, 99.55951), (46.51202, -51.04216, 95.692474), (47.8633, 52.04546, 98.03368), (-49.26469, 46.321186, 100.11689), (35.02517, 35.041924, 99.55951), (47.8633, 52.04546, 98.03368), (46.51202, -51.04216, 95.692474), (49.46269, 35.025063, 85.12075), (47.8633, 52.04546, 98.03368), (49.46269, 35.025063, 85.12075), (42.79253, 50.001457, 7.208085), (-44.046192, 46.11, 6.038819), (-44.046192, 46.11, 94.13118), (44.046192, 46.11, 6.038819), (44.046192, 46.11, 94.13118), (-46.10997, -44.04618, 6.038819), (-46.10997, -44.04618, 94.13118), (-46.10997, 44.04618, 6.038819), (-46.10997, 44.04618, 94.13118), (-44.046192, -44.04618, 96.195), (44.046192, -44.04618, 96.195), (-44.046192, 44.04618, 96.195), (44.046192, 44.04618, 96.195), (46.10997, -44.04618, 94.13118), (46.10997, -44.04618, 6.038819), (46.10997, 44.04618, 94.13118), (46.10997, 44.04618, 6.038819), (44.046192, -44.04618, 3.9750009), (-44.046192, -44.04618, 3.9750009), (44.046192, 44.04618, 3.9750009), (-44.046192, 44.04618, 3.9750009), (-44.046192, -46.11, 6.038819), (44.046192, -46.11, 6.038819), (-44.046192, -46.11, 94.13118), (44.046192, -46.11, 94.13118)]
                texCoord2f[] primvars:st = [(0.044952393, 0.4506836), (0.045837402, 0.44335938), (0.07904053, 0.45166016), (0.23254395, 0.9773407), (0.20361328, 0.9762726), (0.23242188, 0.9699402), (0.30249023, 0.90478516), (0.29614258, 0.90405273), (0.30200195, 0.87194824), (0.095458984, 0.971756), (0.06695557, 0.9688568), (0.09625244, 0.96347046), (0.09844971, 0.9650879), (0.12915039, 0.9659729), (0.10003662, 0.9713745), (0.48095703, 0.9659424), (0.4814453, 0.9742737), (0.4494629, 0.9667969), (0.21179199, 0.8405762), (0.21179199, 0.8701172), (0.16772461, 0.8405762), (0.16772461, 0.8701172), (0.55566406, 0.852417), (0.55566406, 0.822876), (0.5996094, 0.852417), (0.5996094, 0.822876), (0.83496094, 0.7907715), (0.8642578, 0.7907715), (0.83496094, 0.83483887), (0.8642578, 0.83483887), (0.69189453, 0.8607178), (0.69189453, 0.83117676), (0.7363281, 0.8607178), (0.7363281, 0.83117676), (0.75683594, 0.8572998), (0.75683594, 0.8277588), (0.80078125, 0.8572998), (0.80078125, 0.8277588), (0.5488281, 0.86486816), (0.50439453, 0.86486816), (0.5488281, 0.83532715), (0.50439453, 0.83532715)] (
                texCoord2f[] primvars:st1 = [(0.42944336, 0.3774414), (0.47387695, 0.38330078), (0.4230957, 0.5949707), (0.40551758, 0.44433594), (0.22106934, 0.4375), (0.40454102, 0.39746094), (0.9472656, 0.7869873), (0.90722656, 0.78234863), (0.94384766, 0.5776367), (0.8833008, 0.7885742), (0.70166016, 0.7701416), (0.8881836, 0.73583984), (0.00033545494, 0.40771484), (0.19628906, 0.41308594), (0.010757446, 0.4477539), (0.6767578, 0.6040039), (0.68115234, 0.65722656), (0.47631836, 0.609375), (0.20166016, 0.79833984), (0.20166016, 0.99193573), (0.00806427, 0.79833984), (0.00806427, 0.99193573), (0.00806427, 0.78234863), (0.00806427, 0.5888672), (0.20166016, 0.78234863), (0.20166016, 0.5888672), (0.63671875, 0.79833984), (0.8305664, 0.79833984), (0.63671875, 0.99193573), (0.8305664, 0.99193573), (0.21765137, 0.78234863), (0.21765137, 0.5888672), (0.4111328, 0.78234863), (0.4111328, 0.5888672), (0.21765137, 0.99193573), (0.21765137, 0.79833984), (0.4111328, 0.99193573), (0.4111328, 0.79833984), (0.62060547, 0.99193573), (0.4272461, 0.99193573), (0.62060547, 0.79833984), (0.4272461, 0.79833984)] (
so does usdimport cannot load default variant or my fault?
