Error Unable to find layer file:
   2986   3   0
hey there,
Windows
houdini 19.0.622
python 2
I'm trying to export some curves to solaris and I'm running into this error.
The usd that I export works in usdview but it doesnt work when I try to bring it into solaris, please see below images
Edited by suemarisauer - Aug. 12, 2022 06:40:27
The path expression looks mangled. Why do you have `$JOB+" instead of just ${JOB}
Edit: Oh that's on the output.
It looks like you're on windows, but the path on the read node doesn't start with a letter. Are you sure you put the path in correctly?
Edited by jsmack - Aug. 12, 2022 12:38:41
I had the same issue while trying to reference the .usd file in solaris. The issue was the spaces in the full file path. I had to rename the folders from "D:\1My documents\..." to "D:\1My_documents\..." and so on for every folder in a path and the error disappeared.
I ran into the same issue and was able to solve it by just putting the File Pattern in quotation marks in a reference lop: "G:/My Drive/work/2023/solaris_test/geo/manyshapes.usd"
