can't find how to change input names and labels using python. (see image for reference)
thanks
Jonathan
Subnet rename inputs / labels using python
977 1 0- Jonathan Pepin Gagné
- 2 posts
- ASquirrel
- 231 posts
Hello, I know this is a bit of an old thread, but I wanted to update it with the solution for any futures reference :
The subnet plug name are actually houdini's parameter and can be simply renamed with node.parm("").set()
each plug have 2 parameter respectively named "name1" "name2" "name3" "label1" "label2" "label3" up to 64
exemple :
Hope it help !
exemple :
import hou subnet = hou.node("/mat").createNode("subnet") subnetoutput = subnet.node("suboutput1") textureNode = subnet.createNode("texture") subnetoutput.setInput(0, textureNode, 0) subnetoutput.parm("name1").set("myfirstinput") subnetoutput.parm("label1").set("Fancy Label")
Hope it help !
Edited by ASquirrel - Sept. 17, 2023 06:23:16
Head of Pipeline @ LightVFX
