Hi all ,
In the help for the volumesmoothsample vex function, there are two images that show interpolated fields based on a series of known positions. I was hoping to extrapolate this to generating a heightfield via a wrangle where the sample points are fed into the second input. What trips me up is that I would expect it to need multiple input points to find the weighting and 2d position to sample from but you're always sampling a known P + an offset because you don't want to same @P directly otherwise you'll return the heighfields value at that location.
Volumesmoothsample
1602 5 0- zampha
- 10 posts
- animatrix_
- 4703 posts
The smooth interpolation is used to interpolate between the voxels when sampling a single position, not to interpolate between multiple arbitrary positions from the field.
- jsmack
- 8041 posts
- zampha
- 10 posts
Many thanks for the reply. Fortunately I'm working through your excellent Pragmatic VEX series as I thought it might be the case, that it wasn't going to work; so my guess is I will be looking to extrapolate point based interpolation from 1D to 2D so I'll need four reference sample points rather than two. I don't suppose you would have any tips for getting started on that please ?
- animatrix_
- 4703 posts
zampha
Thanks a lot for your words For this I would use the spline function:
https://www.sidefx.com/docs/houdini/vex/functions/spline.html [www.sidefx.com]
It supports various interpolations like linear, cubic (Catmull-Rom), K-Spline, Bezier/B-Spline/Hermite. I will probably cover these in Volume 2.
jsmack
I'm sorry, smoothsample? did they add some cubic or catmull thing for volume sampling?
https://www.sidefx.com/docs/houdini/vex/functions/volumesmoothsample.html [www.sidefx.com]
https://www.sidefx.com/docs/houdini/vex/functions/volumecubicsample.html [www.sidefx.com]
https://www.sidefx.com/docs/houdini/vex/functions/volumesmoothsamplev.html [www.sidefx.com]
https://www.sidefx.com/docs/houdini/vex/functions/volumecubicsamplev.html [www.sidefx.com]
- zampha
- 10 posts
