Hey,
Windows 10
Houdini 19.5.303
Gpu: 3090
I get this running an OpenGL rop via Deadline.
OpenGL Fatal Error: The installed OpenGL driver is not able to run OpenGL 3.3. Please update the driver and check the minimum system requirements for Houdini (www.sidefx.com/sysreq)
I'm running NVIDIA driver v516.94.
Note: It works fine if i remote in, open houdini, and hit render. It reports Opengl version 4.6.0
Any ideas?
Cheers
Nick
Open Gl ROP: Fatal Error
2289 2 1- Nick Deboar
- 24 posts
- sanostol
- 577 posts
hi, not sure if this is might be You problem as well, but I had to start the dispatcher service on the local system account, as windows does not allow access to the gpu otherwise. they changed this behavior in windows some time ago.
You can try it by stopping the service in the service manager and the start it manual on Your machine, so it runs with Your user rights. it is not optimal but there for us there was no way to run opengl captures with on the renderclient running as a service
maybe it works for You as well
- Nick Deboar
- 24 posts
