Hi everyone, I seem to be having an issue setting up the Aces OCIO with Houdini 19.5
I created an environment variable named OCIO to load the color profile in, and it seems to be loaded in correctly in, however i cannot see the the blue'ish tint that you would get with Houdini 18.5 when Aces was installed.
From the looks of it, the color settings show the correct path, and Aces shows up in the Color Correction toolbar in the viewport, but the blue'ish tint isn't there. (The blue'ish viewport tint is there when i start Houdini 18.5, and it's pointing in the same file path as the one in Houdini 19.
Any help would be appreciated
Not sure if Aces OCIO is working correctly in Houdini 19.5
2102 1 0- K3DFX
- 3 posts
- jsmack
- 8042 posts
K3DFX
There should not be any blueish tint. That was a bug in earlier versions of Houdini.
