I am trying to export out alembic animations from frames generated earlier in the process.
I tried partitioning the frames into a single work item and then using the alembic rop node as well as a rop fetch but have only been able to get the first frame to export so far.
How do you export alembics from a frame sequence?
1072 0 0- breht
- 11 posts
