does anyone know why when importing an fbx all the parameters turn brown?
Thank you to everybody!
parameter's brown color
1605 2 1- palazzinaro
- 9 posts
- tamte
- 8784 posts
When Auto Takes is on parameters unchanged in current Take are such color
It usually means you are in non-main take which may be the case when importing fbx at object level as FBX import can import animation clips as takes
so first of all I'd turn off Auto Takes as it can be very dangerous if you are uaware
and then switch take to Main, unless you intend to be viewing different take
Edited by tamte - Oct. 16, 2022 13:21:04
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- palazzinaro
- 9 posts
