Is Karma pixel filtering working?
I am trying to render a Depth pass without anti alias and it is not making a difference change the filters.
I am using build 368.
Karma filtering issue
2643 10 1- mzigaib
- 975 posts
- mzigaib
- 975 posts
- BryanRay
- 43 posts
Not all of the filters are implemented yet.
https://www.sidefx.com/docs/houdini/solaris/filters.html#pixel-filters [www.sidefx.com]
I presume you're attempting to use the "Disable Edge Antialiasing" option, which sets the filter to ? As indicated in the documentation, the edge mode is one of the filters that is not currently implemented. I am not sure what the fallback value is, but it's probably the default of zmin.
- mzigaib
- 975 posts
- mzigaib
- 975 posts
- mzigaib
- 975 posts
- BryanRay
- 43 posts
I just came out of a meeting with the rendering folks, and they said that the pixel filters aren't implemented in Karma XPU at all. But do note that XPU is still beta. Karma CPU behaves as described in the docs—you can specify a non-antialiased depth AOV using your choice of the min or max sample at each pixel. Edge mode appears to fall back to Average.
I'll submit a ticket to have the docs updated to indicate that XPU does not support the pixel filters at this time.
- mzigaib
- 975 posts
- ali_f
- 42 posts
- mzigaib
- 975 posts
- dafloW
- 4 posts
